The R32 GTR loom would be a closer up front match I think. Why are you wanting to change it anyway?
The Nissan Australia R32 GTR Manual has wiring diagrams for GTS4 included and they are very similar.
It would be great if you gave a far greater explanation on your situation detailing all faults and symptoms!
We cant be mind readers and the more hard facts allows a greater scope of someone regcognising the problem and suggesting an easier fix.
I had loom problems also but the LAST thing I was going to do was swap it!!
I traced the faulty cables and ran replacement wires back to the ECU to solve the breaks.
Admittedly it did not solve my Knock Sensor problems but the only way I managed to do that was shorting the wires to earth thru a resistor so fooling the ECU that the Knock sensors were OK and no Fault code displayed.
the problem with the loom is that it is burnt, no changing the wirs on that 1. its stuffed. so thats why i require a gts4 loom but i have agtst loom wanna know the major differences but i think the awd plugs required are not there on a gtst loom, can some one confirm or get back to me with the wiring diagrams for both cars
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
