HI folks,
As i'll be looking for a turbo (streetable although with ability to produce ~250rwkw) for my Sierra Cosworth, i was just wondering if anyone has done a comparison (practical/theoretical) between any of the Trust T67 and the equivalent HKS GTxx turbos?
i know that the HKS turbos have the advantage of the ball-bearing cartiridges and the 'new' design wheels/housings, although, not many people talk about the trust range of turbos even though most of the big hp GTRs and Supras in Japan run single Trust turbos.
Does anyone know the actual hp the T67 can support?
anyway, thanks in advance for your help.
cheers, RS500.
Thanks for that Merli.
The reason i ask is that i was thinking of going for the Trust T67-25G (8cm exhaust housing) on my 2L and was wondering if it will be streetable and at the same time be able to produce reasonable and streetable hp.
Streetable is a very subjective term... Some people love cars that don't spool up until 5000rpm, others want as much low down grunt as possible so they can be heros at the traffic light grand prixs...
I've got an HKS GT3040 on a 2.5L, and it's got a ball bearing core.. It makes 1 bar by just under 4000rpm...
The T67 is slightly larger (albeit with the small 8cm2 housing you want), it's non-ball bearing, and you're running it on a 2L... I can forsee it to be quite laggy...
BTW, if you only wanted 250kw @ wheels, you don't need to go anywhere NEAR as big as the T67... That will put out approximately 350kw @ wheels...
Look for a 400-450hp rated turbo...
For comparison's sake, my HKS GT3040 is rated to about 500hp.
It makes 280rwkw @ 1.2 bar, and is rated upto 1.8 bar (should be around 320-330rwkw)
The Trust T67 is rated at 550hp, so it would make around 350rwkw like I said before...
I used to run my HKS GT3037S turbo on a 2L and I can tell you that it is quite laggy. Not much boost was made until after 3500rpm. The turbo is quite "smallish" in that it has a 0.6A/R compressor housing and a small 0.73A/R exhaust housing. Which is on the smaller scale of the GT3037S turbos. They can go over 1.0 A/R for the exhaust housing. The power was good though, making 206kW@four wheels at 1.2bar. This was on my EVO4. For street use, I wouldn't go any larger than the GT3037S.
Remember that the TRUST turbos are normal bearing and so will have more lag than the equivalent HKS turbo. I think the GT3240 is the largest BB turbo HKS makes? The larger turbos are all normal bearing like the TRUST ones.
Hehe...no, that is when the car started boosting. I might not be accurate, but boost probably came on a little earlier than 3500rpm. You could probably hit 1bar boost around 4000rpm, maybe just after.
No internal mods were done to the engine. But if you had the $$$, you could buy longer duration and higher lift cams and cam gears and that would make the car make boost a little earlier. Really, if you want the best out of a big turbo you should run highish boost. Although HKS and Garrett turbos are similar, it's been stated that Garrett turbos are more efficient at lower boost (under 1bar), whereas HKS turbos are most efficient at high boost (1.5bar). So it's best doing internals when making the most out of an HKS (or any other large) turbo.
This used to be true up till about a year or two ago when HKS released an updated T51R range (KAI and SPL) with ball bearing cores :P;):D
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
