Hey guys ive decided to sell my car i think ? to find something more practical for work and getting back into karts to tow a trailer with, im not very familiar with prices so i was wandering if anyone could give me a base to start with.
1993 r33 m-spec GMG
gt3076 Int Gate
FMIC
Ems Stinger tuned by overboost
Nismo 740cc injectors
Exedy heavy Duty 5 Puk clutch (recently installed 400ks)
Turbo back exhaust (screamer pipe) (custom rear muffler by kermit, Loud)
Mushroom Pod
blitz bov
GTR Drivers Bucket Seat
Momo Steering Wheel
There may be more cant think at this time however it Made 375hp on 18psi and around 355 on 15psi at ovaboost, great car however didnt get driven much im still young and always worry about cops seeing the P plate other then that it drives great and has been always regulary serviced. You may have seen it driving round DISCR33T, let us know what you think guys il try get pics asap.
Edited by Sammie
https://www.sau.com.au/forums/topic/195094-pricing-my-car/
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
