So considering that my nicely tuned RB25NEO will ping on anything less than 98 octane, which one do you think I should use?
Seriously though, I'll bet the second two cars in that video aren't actually supposed to run less than 96 octane fuel (manufacturer specs) so the findings weren't surprising there either.
Skylines are designed to run over 100RON fuel (available in japan)...so running 91 octane fuel (regular unleaded) in your skyline is not a very good idea in my opinion. The extra few $$ not only gives you more power and better economy (not necessarily the case with cars not intended for premium fuel), its also very cheap insurance for your engine :P
As for the difference between optimax and ultimate, I'd say that varies between cars and even if the cars are the same model and everything. :)
For what its worth I use BP ultimate...but the main thing is that you choose one and stick with it because you'll only get the best from it if you continue to use the same fuel and not mix it with others.
Edited by pixel8r
Skylines are designed to run over 100RON fuel (available in japan)...so running 91 octane fuel (regular unleaded) in your skyline is not a very good idea in my opinion. The extra few $$ not only gives you more power and better economy (not necessarily the case with cars not intended for premium fuel), its also very cheap insurance for your engine :wave:
snap! couldn't agree more
these topics have been done to death too :worship:
I remember someone saying that Japan's RON rating system is different to Australia's. Their 100ron is equivalent to our 98ron. Can someone confirm?
I always thought that japan's fuel was more like 106RON. All the same, I think america's fuel uses a different RON rating - not sure about japan though.
I just know the higher the octane rating the better. They run great on 98RON and 100RON here in australia so not much to worry about. :)
Just thought I'd also mention - the reason for the low difference in the cars in the video is that those cars were all built for export markets - in this case, the UK. This means that the cars are designed to run on the fuels that are available in that country, and tuned for the same.
The difference with skylines etc is that they were not intended for any market outside of japan and so they are only designed for japanese premium fuel. A skyline would've seen even more difference between the fuels than the 3 cars in the video...
As a side note, I believe the UK did actually import skylines at one stage, but i'm not sure if these were modified in any way to suit UK emissions laws etc.
lmao call a current affair :P .... seriusly, there are soooo many variables to consider it is impossible to run a test like that. oh and its not just RON that makes fuel better it oxygen content etc.. i use ethanol based (e10 i think , 98ron with a high oxygen content) in my 33 because its my daily and i cbf getting it tuned (the higher oxy content leans the fuel mixture out a little, even though the ecu would offset this somehow ).
rubbish. my car (stock) pings on 98 RON, on 100 RON it is beautiful. jap fuel is definitely 100 RON or better.
Well if Wikipedia is right, which is not all the time:
http://en.wikipedia.org/wiki/Octane_rating
Japan and Aus are probably using the same ratings for Fuel, Japan just gets better fuel :)
So the "myth" (as this thread suggests) is not a myth after all.
Keep using 98 octane or higher fuels people. :)
Dont use 91 octane regular unleaded just because some guy in the uk with a renault clio said it makes no difference.
The manufacturer recommends 98-100RON (or higher, whatever they have in japan) so go with that.
Nothing new here...move along.
I agree to stick with the 98 RON. The reason why we here in Australia can get away with 98 instead of 100 RON, is due to our altitude. Pretty much all of Aus is pretty close to sea level cause its such a flat country. Japan is generally a lot higher. At higher altitudes, you need a slightly higher RON (ie 100 RON) to make up for the thinner air and therefore less oxygen content. I wouldn't go less than 98 as lower may ping in Australia, but I reckon in the high mountains in Japan, 98 would still ping.
I just know the higher the octane rating the better. They run great on 98RON and 100RON here in australia so not much to worry about. :(
where do you get 100ron fuel from?????? and i use shell V power 98ron since there is a shell near my place.
Edited by slverbullet
shell vpower racing (previously called optimax extreme or something). It contains 5% ethanol as far as I know.
not to be confused with the normal shell vpower which is 98RON and contains no ethanol.
What a joke. To say regular unleaded at ~91 Octane is equivalent to 98 Octane fuel is that full of it it's not even funny. BP ultimate for me thanks!
Cheers,
That clip was from Fifth Gear in the UK, where regular is 95RON.... In Australia regular petrol is an even lower 91RON, so the difference between Regular (91) and High Octane (98) would be more pronounced in Australia. But also, as mentioned in this thread most skylines would ping terribly on 91 let alone 95...
On a practical sense fellas... I can actually feel the difference - I personally like Shell's V-Power... runs heaps better as opposed to something like 91 Octane petrol... so I guess it's worth the extra buck.
Here's what the Pom's think of Shell's so-called "super fuel" V-Power...
http://www.japmobiles.com/news/news_detail.asp?id=245
91RON and 98RON, with the timing set to handle the 91RON? Of course you're not going to get that much effect (though there will be some, 98 still burns better, the timing just isn't set up to take advantage of it).
But with 98RON you can put more timing in (either manually, more commonly automatically by the ECU these days) and get a whole lot more economy/power out of it. The opposite being the reason why 91RON pings, because the timing is too far advanced and is causing preignition.
I see 95RON becoming a thing of the past here in australia, with a lot of euro/jap cars coming over requiring 98RON.
Most Euro and Jap cars are built for 98RON fuel or more, but most owners don't realise this and still fill up with 91RON. I guess if they don't thrash the car everywhere then it should be alright for now.
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
