Just want some feedback from those who have had their injectors cleaned. I'm planning to get it done and was wondering if it is really worth doing. I usually run an injector cleaner through it every 5000km. The car has done just over 100,000km.
Will there be much of a performance gain? Or is it more for drivability/engine smoothness? Approx cost?
Any feedback would be great. :)
https://www.sau.com.au/forums/topic/19512-injector-cleaning/
Depends how clogged they are.. if they're only operating at 60% efficiency then you will receive power gains.. even if just one or two is clogged slightly, you'll get uneven firing into the cylinders which will affect the overall power.
You have any quotes on cost and places in Melb where you are planning on getting it done? thinking about it myself.
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-411564
Steve: I think they might need a clean coz the engine coughs and splutters (only slightly tho) over 5000rpm. I'm gonna get the plugs done and see if that makes a difference first.
My mechanic said that dirty injectors should be felt throughout the rev range not just up high? So he said done worry about it yet. He quoted $300 to clean all 6, labour inclusive obviously.
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-411920
Hey rig check the gap in ur plugs sounds like the coils are slowly getting tyred and the gap is too big.Asa for injector cleaner i hate the shit i think it makeds ur injectors dirtier.The chemicals in injector cleaner dissolve any crap that is blocking the tiny holes inthe injector jet .This same crap is found in your tank and fuel lines.There fore the injector cleaner is dissolving the crap in ur tank and trynig to piss it out of the injector sometimes making the problem worse.I would check the plugs out first !
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-413846
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
