Just want some feedback from those who have had their injectors cleaned. I'm planning to get it done and was wondering if it is really worth doing. I usually run an injector cleaner through it every 5000km. The car has done just over 100,000km.
Will there be much of a performance gain? Or is it more for drivability/engine smoothness? Approx cost?
Any feedback would be great. :)
https://www.sau.com.au/forums/topic/19512-injector-cleaning/
Depends how clogged they are.. if they're only operating at 60% efficiency then you will receive power gains.. even if just one or two is clogged slightly, you'll get uneven firing into the cylinders which will affect the overall power.
You have any quotes on cost and places in Melb where you are planning on getting it done? thinking about it myself.
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-411564
Steve: I think they might need a clean coz the engine coughs and splutters (only slightly tho) over 5000rpm. I'm gonna get the plugs done and see if that makes a difference first.
My mechanic said that dirty injectors should be felt throughout the rev range not just up high? So he said done worry about it yet. He quoted $300 to clean all 6, labour inclusive obviously.
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-411920
Hey rig check the gap in ur plugs sounds like the coils are slowly getting tyred and the gap is too big.Asa for injector cleaner i hate the shit i think it makeds ur injectors dirtier.The chemicals in injector cleaner dissolve any crap that is blocking the tiny holes inthe injector jet .This same crap is found in your tank and fuel lines.There fore the injector cleaner is dissolving the crap in ur tank and trynig to piss it out of the injector sometimes making the problem worse.I would check the plugs out first !
https://www.sau.com.au/forums/topic/19512-injector-cleaning/#findComment-413846
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
