  • Replies 107
i can agree with that. its nice to get out there and have a fast run through the twists but there is no point gettin up behind someone pushing them to the point that they endanger themselves and others on the road. not everyones cars are set up as well as other too! once again great day had my.... most lol. soz, forgot to blank out plates in the few pics i put up too!
brett
one of the smarter things ive heard :O
Sounds like u all had a good time! Ill have to catch u all on the next one :(
Who owns the bayside blue R34GTR? :worship:
i feel so sorry for cheez, hope everything goes ok with claim process dude, keep us informed.
Do u really think that was necessary to make public?
yes an awsome days outing (apart from the obvious :worship: )
lol dought it was me pushing the ppl in front of me as the only stocky i saw there i was decidedly embarresed :(
certanly some nuts cars there yesterday and was great to see everyone havin a gd time
my only beef is with the pub we got lunch at... anyone else hav a chicken parma... omg worst. parma. ever.
Thanks for the great cruise Daniel! We had an awesome time. I don't think I've been down that back way home before, but those roads were brilliant - loved every minute of it!!
See ya all at the next cruise :worship:
btw, I'll post my pics up soon.
Re: Ferrari - was that the F430 coupe or Spider?
We saw a coupe coming the other way, a spider with personalised plates in Lorne.... but one of my customers was out in our red F430 Spider coming back from Apollo Bay via the Ottways too.
J
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
