I think we should all take our turbo's off when we go on cruises so there is no temptation to drive our cars as they should be driven. Shame on us all....
The problem isn't in people driving the cars as they should be driven. The problem is people driving them how they shouldn't be driven. And the biggest problem is that so many people don't know the difference between the two because they don't know either the limit of their own driving ability or their cars performance ability.
  • Replies 107
Yeah... AT A TRACKDAY NOT A PUBLIC ROAD
Winton Trackday on 25th November was a good one thank you Ash :)
During the previous GOR cruise, there were already a few drivers who drove dangerously. Cutting into traffic from the opposite direction at corners.
Suggestions can be:
1) Warnings sent out to the respective drivers which gone out of hand
2) A briefing about Do's and Don'ts before the cruise commences.
Well I would not consider any of that example to contain any wrong behavior!
All cars were safely on their own side of the road and none went over the centreline coming around the corner at a reasonable speed.
The only issue was the "f" word when you thought some were going to pull in and stop! :nyaanyaa:
To be honest I have avoided some of these runs because I know sometimes my adrenelin can get going and thats when stuff happens if its going to happen.
But thats because I have not done to many DECA's or Track days for a while to get it out of my system and get to know my and the cars abilities better.
The people on this run that let their head go a bit will realise who they are and should say to themselves..
-I WILL JOIN SAU and get my head together by doing it on a racetrack under safe controlled conditions! (and have the most fun in a Skyline with your pants on!)
How about it Daniel, and you to Adam!
</Oldie Lecture>
if i get the skyline fixed i definitly will. if it gets ridden off i dont kknow what car yet. if its another skyline, yeh ill be a member and forget the cruises and stick to deca and track days.
get a vx commo with cut springs and be hectic
The only issue was the "f" word when you thought some were going to pull in and stop! :D
</Oldie Lecture>
Is this aimed at me? If it is, I'm not even 18 yet! :spank: I'll be getting my licence mid January (hopefully pass) so will be signing up soon. Don't worry. If it wasn't aimed at me then..... my bad. :P
im actually really looking forward to joining SAU and meeting new people and going on the official cruises. i think no matter what there is always somebody that doesn't think and will do something silly and thats because they are probably running on adrenaline. i think every car should have classical music playing in there car you will be too calm and relaxed to to do anything stupid :rofl: . my car probably won't fit in with all you guys and girls cause mine is completly stock and i think that is a good enough excuse to fix it up a bit, woohoo time to spend some money!!
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
