hey all got the usual shit squeal with my r33, no matter what i do they sqeal
what ive done
new rotors front and back, slotted from the group buy
cheapie pads up front
cheapies at rear (different brand)
and guessing stock nissan handbrake shoes
used anti squeal, and i have all my shims
bled the system and have braided lines not like it makes a difference
bed them in properly but still got the squeal
sometimes it comes from the front, sometimes back sometimes both and yes EVEN the handbrake squeals (use it sometimes coz its so embarassing pulling up to lights on a bad day)
so the only common thing is the brake rotors... it is only when slowing down say under 30kms an hour they start to squeal
WHY WHY WHY
anyhow they weren't as bad before (still some squeal) with standard rotors and standard nissan pads up front so this is not acceptable, there has to be a reason.... cannot just say thats the way it is
anyone have anything i can try or any theories??
https://www.sau.com.au/forums/topic/195154-yes-another-brake-squealing-thread/
  • Replies 61
Posted Images
were the rotors completely clean before you took it out to bed in the pads, did they have any greasy finger prints or oil still on them, as when the brakes get real hot left over gunk on brakes tend to cook and make them squeal.
Just a thought.
I'm having the exact same problem but with stock 33gtst rotors and bendix ultimate pads. It's got us stumped, the only thing that has had any effect on the squeeling was lubing between the calipers and the back of the pads but even that only last a couple of days.
Doesn't do it EVERY time but more often than not and it's when I brake lightly coming up to traffic lights etc. Mechanic says he can feel a vibration when it does it.. going to try skim the rotors next and see if that helps.
i get the same problem, only without the vibration. i put my problem down to brake dust....
however, with a vibration, it could be number of different things. a slightly loose bolt in the caliper, shims missing or around the wrong way or even just a small stone stuck in your brake pad...
I don't think it's a huge vibration as I can't feel it, he was in the passenger seat when it squeeled bad and said it was a vibration.. I think the squeeling is a minute high frequency vibration.
I should really have skimmed the rotors when I put them on, they are 2ndhand 33gtst items. Looked fine when I put them on but the bendixz pads seem to have lipped the rotors fairly quickly :(
Edited by bubba
i would hardly think using brake cleaner would cause squeal as that is its designed purpose
i might try this copper grease just got a laugh to see what happens
just to make sure i do it correct there is 2 shim and then the pad
so...
piston -> shim 1 -> shim 2-> brake pad -> rotor
so i put grease between piston and shim 1 & shim 1 and shim 2 and even between shim 2 and brake pad?
what is actually squealing? is it the pad on the rotor or caliper piston on the backing plate of the pad? im just unsure thats why im asking. does it only do it wen braking at low speeds because you aren't putting as much pressure on the pedal and so the pad/caliper piston is only slightly engaging?
my car is doing the same after putting in bendix pads, its pretty annoying to say the least
Edited by white33gtst
I'm running bendix pads aswell, does it at low speed with light pedal application but once it starts squeeling, it doesn't matter how hard you push the pedal - it doesn't go away till you come to a dead stop.
did you bleed the brakes after resetting the caliper pistons to put the new pads in? if there is air in the brake lines would this give the caliper piston some play? that would let the brake pad vibrate slightly enough to give off the high frequency squealing?
ok just noticed u did bleed the brakes. did u bleed them at all 4 corners?
yeah i did but im going to do a full brake flush when i get the chance with some new fluid and thinking of getting some QFM pads for the front, use copper grease and hopefully i get some better results
with standard rotors and stock nissan pads it done it maybe 20% of the time but this is like 80% if not more
