so you mean the top and bottom of the pad when they are sitting in the caliper has some play and wear out the caliper?
Yep, there has to be some room for differential expansion of the pad and calliper. But too much and they vibrate.
Cheers
Gary
  • Replies 61
Posted Images
good idea gary, would explain everything as i have tried many combinations of pads/rotors/glues and still have the same noise
still not 100% on how im going to fix it tho... so you actually welded onto the backplate of the pad thereby making it saw 1 or 2mm longer?
maybe i could use some silicone or rubber there to stop it? dont have a welder to try your method
just installed the rear qfm brake pads, took them for a bed in session
f**k me they squealed so hard like a blood curdling screech!!!!!! like the usual noise but amplified 1000times lol
will wait til they cool down and see how they go however its not a good start
Is that the HP-X or A1RM QFM Brake pads?
Also is that with RDA or standard rotors?
Screeching louder then when you had the Bendix Ultimates on?
It is with the 500deg ones on both front and rear now
they are the group buy slotted rotors so not exactly sure if rda or dba
yes i must say it has gone worse now (had cheapie brake pads on before not ultimates). I must try the stick on shims
im so over this squealing crap. I dont want to go to any brake place and ask them to fix coz i know they will say "machine rotors first" so theres about 100 bucks front and rear at a guess and i know this isnt the problem. Unless someone knows a place that will not dick me around
picked up some shims today to try pity they only had 1 set so i cant do the rears but will keep you updated
the shop rekons its coz i got qfm pads on... hmm i sense a trend happening
every shop rekons its the brake pads... ive gone through 3 different names and still the same so i rekon they are full of shit!
well took all pads out, roughed them up so they arent glazed
put adhesive shims on the front
hey guess what
they still squeal
going to get the rears to make sure its not just the rears squealing. too hard to bloody tell which ones it is
Does it real bad when going downhill like in a car park or the like
so im guessing on a downhill it would use the front brakes even more correct?
if thats true there goes my theory of its the back brakes
^^^ You must have tried nearly everything under the sun by now! lol I've got the same problem, but my squealing is amplified when the rotors are wet after it's been raining. But this is where it gets weird.... after I wash my car, I pressure hose the rotors through the wheels. I do this because I think the brake dust may be contributing to the squealing. This HAS helped somewhat and I get squealing probably only 40% of the time now. It doesn't always squeal either which has baffled me. Again like you, the squealing is only when coming to a stop.
Try running your finger over the rotor or around the inside spoke of your mags and see if you get a lot of brake dust. I also understand this was not an issue much with cars before they had to stop manufacturing asbestos brake pads. I could be wrong though.
I mostly get squealing first thing in the morning, and at the occasional traffic light. But after that it's pretty good. I definately get less squealing in the summer though I have noticed.
This probably isnt going to help much but i was told that the squealing is caused by the piston to shim/brake pad surface. Before i ran my caliper upgrade, i was using the following and had no squeal with DS2500s
Piston -> red rubber goo -> shim1 -> nissan pad grease (still there, just re-spread it out) -> shim2 -> pad
IIRC the goo needs to be left for 10mins. Maybe if you dont let it dry a bit you just push it all out when you first apply the brake. Is the grease you got especially for brake shims or is it just regular copper grease?
PM me if you want to come to Syd inner west to let me have a look. I'm no expert but a new set of eyes may help.
well omfg i may have fixed it
well anyway we will see how it goes in a weeks time
used grease on the pins and retainling clip where pin makes contact and in between shims. Also used the rubber anti squeal shims on the back of the brake pad and no squeal!
went for a 45 min drive and only had 1 real minor squeal out of the whole drive
maybe my joy will be short-lived but f**k does it sound good when theres no squeal
Hey tek!
Fantastic that you have finally resolved it. I also used the red goo and maybe for 2 months the noise was gone, loved it.
It is bad now though, after about 10 mins of driving, any soft application of the brakes coming to a stop (once in a while) it will screech like crazy.
Did you grease the two pins that align the pads correctly? just run grease up and down them?
And then grease the retaining clips, which ones are these? I am guessing those wire type clips, if so which part of them?
Finally, I take it from above that you also tried rubber goo on the back of the shim so the set up is like this:
piston --> GOO --> shim1 --> GOO --> shim2 --> GOO --> back of pad
just in surfers atm so havent had a chance to check thread.
Basicaly what i have now is
brake pad -> rubber shim -> metal shim1 ->grease inbetween->metal shim2
note, NO goo was used with this setup as it says not to use with the rubber shims
i grease the 2 pins and the clips that holds the brake pads in where it makes contact with the pins. NOT the springy metal bit that goes through the end of the pins as that is the safety mechanism and dont want that sliding out lol
i used wheel bearing grease but now there is a real light squeal after driving to QLD but not bad at all and if it stays like this i will be happy. will try with proper copper grease when i get my hands on some and hopefully it keeps longer
  • 4 weeks later...
^^ how is your squeeling going? i am getting squeeling sometimes, it's becoming just as bad as it was. I was thinking of trying what you did with the two pins but wanted to see how it is now and if it had come back for you?
also what grease do you think would be best to use?
any help would be great as you know my pain lol
just attached a pic so you can point out what you greased and exactly which parts if that's cool.
cheers
Edited by Onthehunt
    • Looking at the photos, you could easily just drop this pipe and dump into atmosphere  Just 1 or 2 quick hits for data acquisition - if have a heat shield material and/or sheet metal, maybe just use wire/metal cable ties and attach it in a way to deflect heat from melting nearby wires.
    • 2025 PRP GTR Festival - A Massive Thank You from SAU NSW! On behalf of SAU NSW, I want to extend a huge thank you to our incredible committee for all the hard work and dedication behind the scenes. You are the engine that keeps this club running smoothly! (hopefully an RB lol馃槅) To all our amazing volunteers who helped make the GTR Festival Sydney such a success, thank you for giving your time, energy and sacrificing your weekend sleep-ins. Your efforts did not go unnoticed and were absolutely appreciated by everyone. We also want to give a big shoutout to the workshops, trade stalls, and the awesome VIP's we connected with over the weekend. Your support means the world to us, and we鈥檙e so proud to be part of such a passionate automotive scene. We are looking forward to collaborating with you at our future events.  SAU NSW had our marquee up for two full days at GTR Festival, packed with merchandise, a sizzling members BBQ, and a chance to chat with the committee, sign up, and check out some hot Skylines on display from our members. It was incredible seeing so many smiles and genuine conversations, that's what we're all about! SAU NSW is more than just a car club... we鈥檙e building a community where you can make friends, share stories, and talk about anything RB related or not. 馃摳 Please post any cool pics you took at the GTR Festival in this thread! 馃摳 To our current members, thank you for your ongoing loyalty, and to all our new members... welcome to the family! We鈥檙e beyond excited to have you on board! Please ensure you are involved as much as possible within the club, and make the most of our exciting upcoming events. Here鈥檚 to more future events, thrilling drives, chill meets and good feeds! Let鈥檚 keep building something special. 馃挭馃殫馃挩 Matt Zoumpoulis, President SAU NSW
    • Yes, well, keep in mind that the air is intake air, which equal boost + possible oil. If there is a fine deposition of oil/scunge that then gets hot and carbonises, it could look just like that. Probably shouldn't be leaking. Might just be normal for that product. Hard to know if it is relevant.
    • Wrapped up putting the motor back in today. I have a stainless flex turbo drain pipe like you see on cummins and that funny enough PRP started selling. I generally prefer these but sadly they come with a finite amount of times they can be bent before they snap. Took well over a week for a replacement to arrive.  I was able to prime the pump but I will more then likely wait until next friday to take it on its madden voyage. I also installed the nozzles for my direct port WMI setup but plugged the nozzle holders for now. I'll tube it with Swagelok SS tubing and fittings next chance I get. No rush, i'll be breaking it for a week or two anyways.
    • I could definitely do some logs without the VCT enabled for sure. I believe we tried it on the dyno and it still spiked but wouldn't hurt to try again and have the logs    I might be able to use some metal cable ties and hold the gate open entirely, I'd need to see about that one.   What do we think about these marks on the cap of the actuator? This is where the two parts push together where the diaphragm spring is. To me they look like air has been sleeping past?? Specifically talking about those black stains above the lower rim/lip. They can be rubbed away as if it's just an exhaust stain.
