Ill try explain the best what happens
when driving between 2k and 2.5k rpm i get a grinding sort of noise in EVERY gear. dont know what it sounds like but its driveline related... mechanic said it was flywheel out of balance or something to that exten.
also i do get axle tramp (well the back jumps up and down uncontrollably when spinning at the end of first gear) I have pineapples and sway bars fitted but still standard shocks/springs
also i get vibrations that are felt through the whole car but especially the steering wheel when i reach approx 105kmph and get worse as i go faster
ALSO feels like when i release the clutch it grabs violently sometimes no matter how gently i try to let go. I dont know what clutch i have in there but it is heavier than standard but dont think its a twin plate (could be wrong)
i dont know if these are all related or seperate but i need to start sorting them out
oh i also get a noise when im stationary in neutral like a whirring from the gearbox bearing that goes away when i press the clutch pedal so im guess input shaft bearing or somethiong like that?
anyhow im thinking centre bearing for the tailshaft for the vibrations? anyone confirm or tell me otherwise?
https://www.sau.com.au/forums/topic/195174-help-diagnose-these-funky-noises/
Yeah, you're throw out bearing is stuffed. That's probably the noise you get between 2k and 2.5k rpm. I was getting it the other night when driving, not doing it anymore though.. always makes noise while idling in neutral. I also have the my clutch violently grip (only once). I'm going to replace my clutch in the next week or so.
Not sure about the vibrations, that could be a poor wheel alignment, tyres or something else.
does the noise sound like a high pitch kind of noise like a fire work shooting off??
cos my r32 is doin the same thing only when its cold but... i think its the same problem as yours, i also got a shuddering from the clutch between 3000 an 4000 rpm in every gear no matter hot or cold...
Yeah like said above, that noise with your clutch in is your throw out bearing
Its inevitable, your going to have to seperate the two to replace the bearing but it soulds like your clutch may of let go, which would explain the vibrations (maybe tramp/violet grabbing also). Like your mechanic said you may have also warped the flywheel and it needs machining.
what do u mean by seperate the two? you mean take the gearbox off so i can get to the bearing or actually open up the gearbox?
throw out bearing = bearing that goes on the fork that presses on your pressure plate?
maybe i shouldnt of used the word violently, its more the feeling of a button clutch (but seems like its getting a bit harsher as time goes on) altho im 99% sure its not a button coz its not on/off there is play there like a normal clutch.. has no problem spinning the wheels either
im quite interested in this aswell actually, if you were to take the gear box off will the be a mark left around the pressure plate of the clutch? i will go take a photo now and post it up of this spare clucth i have and if that is what its caused from pulling out the gear box isnt a hard job and it will be easy to see if thats the problem,
JV
Yep, it shouldnt be the gearbox internals, just something in the bell housing you'd hope. Probably best to seperate the gearbox and the motor and have a peek inside.
My mate had a badly scored clutch that did similar things
sounds like i have to do that... i've never taken a RWD car gearbox out with the tailshaft etc and i've heard you have to rotate the gearbox to get it off as well???
+ its going to be a bucket load heavier than my old n13 gearbox LOL so im a bit iffy about it
Yeh, the 33 Gearbox wil be alot heavier than the N13 gearbox, (someone correct me) but they are around 90-100kg. Possible to "bench press" but the easiest way is with a pit or hoist, with a gearbox stand or the like.
The Whiring sound could be your thrust bearing but without listening to it i cant be too sure. They generally wear out and need replacing every now and then, but to do so u need to do as much labor as required for a clutch change so it can pay to do the change (clutch) when u r changing this over if your clutch isnt in the best condtion.
The Tramp can be put down to many factors (suspension related etc) or even worn drivline bearings, so best to check the suspension stuff out first as thats all simple. Replace any worn part etc, then if it still persists, check these driveline bearings. My car still tramps after doing a full SydneyKid Kit, and checking all tires etc. So im unsure.
Good luck
thanks mate, yeah knew it was going to be a cnt of a job. N13 gearbox = approx 40kg lol! baby gearbox
to make things clear i will explain again, pretty sure everyone understood anyway
pedal is not pressed and gear is in neutral = whirring sound (bearing is making contact and shaft is spinning even tho its neutral)
pedal is pressed = no sound (as this pulls the shaft out of the gearbox so its not spinning no more so no more sound correct?)
hey got a pic of the clutch from my spare RB20, if the clucth has this mark on the pressure plate does that mean the bearing is gone? have a look at the pic, if you pull out your gear box and its the same then that might be the noise,
JV
in that photo, i would think all clutches get that mark after use? but im not sure as ive only ever replaced 1 clutch myself and didnt really have a good look at the old one
i actually got a button clutch + flywheel my old boss gave me that had the exact same noise but it only done it on take off not at about 2k rpm like mine
will have a look at that and see if i find anything sus
hey man hi i have the same problem just started did u find out what the problem was
how did u fix it
guys if you push the pedal in and the noise goes away that means your GEARBOX bearings are shot as the gearbox still spins in neutral, by pushing the clutch you take the gearbox out of the equation. Vice versa and the opposite is true.
The marks on the diaphragm spring on the pressure plate are normal as this is the surface the thrust bearing runs against.
hope this helps.
cheers
  • 3 weeks later...
Just an update, fixed the vibrations at 100km/h
was a wheel balance/alignment issue even tho i bought the car with 4 new tyres they mustnt have been balanced even tho they had the weights on the wheels
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
