Hey
Weird problem... My R33 has started misfiring after I installed a water temp gauge in it a couple of hours ago...
And not your typical on load 5000rpm misfire either.
Basically its idling high (around 1400rpm or thereabouts) and when you tap the accelerator, instead of the revs rising they drop first (say down to around 1000rpm) and *then* will rise.
Took it for a quick drive and feels sluggish and misfiring when depressing the accelerator at low rpm (under approx 2500rpm) and at low throttle (under 20% shown on AVCR)
At higher rpm (around 3k and over) and with more throttle, the car drives fine like it should, makes boost, pulls well etc.
Not sure why this is happening? Drove fine before water temp gauge install, not driving fine now...
Any ideas as to what could have done this?
(ps. Getting the water temp signal from the factory wire going to the ECU. Didnt cut the wire, just stripped it back and joined the gauges sensor wire to it)
maybe adding the extra wire has induced a voltage change in the temp sensor wire, best thing to do would be dissconnect it and see if its still ur problem, if so jus get another temp sensor n get 1 of thost adaptors u put in ur radiator hose n use that instead..
jus 4 my curiosity why bother connectin a temp sensor up? u have one on the dash....
um maybe cause the dash temp sensor isn't accurate & doesn't give an actual temp... you should see the difference between the speedo on the dash and what the PFC says...
Yeah thats a possibility, might give that a go...
Do already have a separate temp sensor that you put inline on a radiator hose, but decided Id try the simpler way of using the factory signal and seeing if that works...
And yeah I realise you have a stock one, but its really quite useless.
It doesnt show you any actual numbers, and it stays in the one spot regardless of actual temp fluctuations - by the time youve seen a change, youve already done damage to the engine basically
could be your AFM... it incorrectly tells the computer how much air when u tap the throttle and therefore the computer dumps too much fuel. The fuel cant all be burned so the car misfires and revs drop.
Definitely havent cut the wire to the ECU, the wire for the gauge was spliced to it.
I cut the wire going to the gauge this morning so it is no longer connected and viola, problem solved!!
Bit weird nonetheless?
Do you consider a misfire the burble noise you hear, or the loud pop, more often than not followed by a orange flame out the tailpipe?
Just curious.. mine very rarely burbles under decelleration, but between gear changes when giving it max boost blah blah, it pops.
Also with that little "tap" on decel it will too :D But thats for Baller flame effect y0. :((im a very new skyline owner, so the flame was ammusing for a while untill i read it can be deadly to your exhaust wheel :) )
you need to fit a seperate sensor for the water temp guage, you can't just go piggybacking the factory ecu coolant temp sensor.
its an nct thermistor so as soon as you alter its resistance by additional wiring and loads, it will give false readings to the ecu.
fit a seperate sensor and disonnect it asap before it burns out the pullup network in the ecu for good.
I was just gonna ask.. even if you read it from your ecu, wouldnt the temp guage still sit in the same spot?
Or will it show the true figures on the guage? but i dont see how, since you still taking it from the ecu.
But i woul be wrong.. just curious thats all
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
