Guest Robo's
Can you guys who have performed a before and after feeling or rwkw increase, post your experiences. For my reading this would have to be the major increase in power, as its straight after the turbo. No use having a strangled exhaust after your turbo then mating up to a gigantic cat-back exhaust. Sounds like your defeating the purpose.
https://www.sau.com.au/forums/topic/19522-your-experiences-with-dump-pipes/
there isnt any noticable kw increase however the car revs a lot nicer and feels a bit more free to drive if that makes sense. oh the car is also more responsive pick up wise and it also made my turbo spooling a lot louder. worth the money with hi flow cat of course
I noticed a gain on the 'seat of the pants' dyno... Maybe about 5-8 cheaks worth (or about 10 skid-marks in the old scale).
It also felt like it spooled up a little quicker and the boost didn't seem to drop off as much high in the rev range.
Worth the money I say.
J
I agree with the posts above. I started with a cat back 4" system and then got a front pipe and split dump. I didn't notice a massive HP gain, but it will come on boost quicker, and increase top end.
As for doing the dump/front first - if you're looking for most HP gain, then the cat back will be better value for money to start with; then do the dump/front pipe. That said, the closer the restriction to the turbo, the greater the effect on flow efficiency; for example, if i put a silencer in my rear muffler (reducing the effective diameter to say 2"), it will have less of a flow distubance and thus effect than having a 2" dump pipe and 4" cat back.
So, in conclusion, do the cat back first, then worry about the dump/front if you are strapped for the mulla. Bang for buck.
When I put my combo dump/front pipe with a separate wastegate line I noticed a fair difference. I already had a catback system too. Although I don't have any dyno figures to back it up, I feel it really helped my midrange as it felt kind of flat before hand.
Probably the best thing about it though was that the turbo was now audible ;)
EDIT: Almost forgot - My combo pipe was HPC coated, so that may have made a difference. Apparently it brings on boost sooner with the coating. If anything I felt it came on boost later, but harder.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
