Guest Robo's
Can you guys who have performed a before and after feeling or rwkw increase, post your experiences. For my reading this would have to be the major increase in power, as its straight after the turbo. No use having a strangled exhaust after your turbo then mating up to a gigantic cat-back exhaust. Sounds like your defeating the purpose.
https://www.sau.com.au/forums/topic/19522-your-experiences-with-dump-pipes/
there isnt any noticable kw increase however the car revs a lot nicer and feels a bit more free to drive if that makes sense. oh the car is also more responsive pick up wise and it also made my turbo spooling a lot louder. worth the money with hi flow cat of course
I noticed a gain on the 'seat of the pants' dyno... Maybe about 5-8 cheaks worth (or about 10 skid-marks in the old scale).
It also felt like it spooled up a little quicker and the boost didn't seem to drop off as much high in the rev range.
Worth the money I say.
J
I agree with the posts above. I started with a cat back 4" system and then got a front pipe and split dump. I didn't notice a massive HP gain, but it will come on boost quicker, and increase top end.
As for doing the dump/front first - if you're looking for most HP gain, then the cat back will be better value for money to start with; then do the dump/front pipe. That said, the closer the restriction to the turbo, the greater the effect on flow efficiency; for example, if i put a silencer in my rear muffler (reducing the effective diameter to say 2"), it will have less of a flow distubance and thus effect than having a 2" dump pipe and 4" cat back.
So, in conclusion, do the cat back first, then worry about the dump/front if you are strapped for the mulla. Bang for buck.
When I put my combo dump/front pipe with a separate wastegate line I noticed a fair difference. I already had a catback system too. Although I don't have any dyno figures to back it up, I feel it really helped my midrange as it felt kind of flat before hand.
Probably the best thing about it though was that the turbo was now audible ;)
EDIT: Almost forgot - My combo pipe was HPC coated, so that may have made a difference. Apparently it brings on boost sooner with the coating. If anything I felt it came on boost later, but harder.
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
