Guest Robo's
Can you guys who have performed a before and after feeling or rwkw increase, post your experiences. For my reading this would have to be the major increase in power, as its straight after the turbo. No use having a strangled exhaust after your turbo then mating up to a gigantic cat-back exhaust. Sounds like your defeating the purpose.
https://www.sau.com.au/forums/topic/19522-your-experiences-with-dump-pipes/
there isnt any noticable kw increase however the car revs a lot nicer and feels a bit more free to drive if that makes sense. oh the car is also more responsive pick up wise and it also made my turbo spooling a lot louder. worth the money with hi flow cat of course
I noticed a gain on the 'seat of the pants' dyno... Maybe about 5-8 cheaks worth (or about 10 skid-marks in the old scale).
It also felt like it spooled up a little quicker and the boost didn't seem to drop off as much high in the rev range.
Worth the money I say.
J
I agree with the posts above. I started with a cat back 4" system and then got a front pipe and split dump. I didn't notice a massive HP gain, but it will come on boost quicker, and increase top end.
As for doing the dump/front first - if you're looking for most HP gain, then the cat back will be better value for money to start with; then do the dump/front pipe. That said, the closer the restriction to the turbo, the greater the effect on flow efficiency; for example, if i put a silencer in my rear muffler (reducing the effective diameter to say 2"), it will have less of a flow distubance and thus effect than having a 2" dump pipe and 4" cat back.
So, in conclusion, do the cat back first, then worry about the dump/front if you are strapped for the mulla. Bang for buck.
When I put my combo dump/front pipe with a separate wastegate line I noticed a fair difference. I already had a catback system too. Although I don't have any dyno figures to back it up, I feel it really helped my midrange as it felt kind of flat before hand.
Probably the best thing about it though was that the turbo was now audible ;)
EDIT: Almost forgot - My combo pipe was HPC coated, so that may have made a difference. Apparently it brings on boost sooner with the coating. If anything I felt it came on boost later, but harder.
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
