Well, the turbo on my 33 died today, warmed it up got 20m down the road barely changed to second gear and bam knock knock knock :) . Didnt even hit boost (i dont hit boost until its at full operating tremperature) Guess i'll be without a car for a few weeks as i can't afford another turbo right now. It was only on 10psi too, so really, there is no safe limit, it's touch and go 82000 kms on the odo. Does anyone have ANY spare turbo for sale that would bolt on? :)
https://www.sau.com.au/forums/topic/19523-turbo-died-today/
I've now clocked 130,000km's. I've been running 15-16psi for over a year now and have done around 30,000km's last year.
Just luck of the draw I guess.
When I had the turbo off the ceramic blades did look like they had hairline fractures but 20,000km's later and its still running.
Couldn't you manually disconnet the wastegate and jam it fully open so the exhaust well most of the exhaust gasses bypass the turbine in turn allowing you to drive it around until you get the new terd?
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-410756
If your ceramic turbo has blown, there should be nothing left of the turbine wheel and then there would be no need to do the waste gate thing u mentioned JOEL.
The easyest way i rekon to tell is to unbolt your turbo down pipe and look inside your turbo where the turbine wheel should be, if theres nothing there then it's deffenitly crapped out.
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-412668
have you had a look at the turbo area?
are you sure that you are not missing bolts of the exhaust or other flanges causing the turbo to knock against the other metals?
as mentioned.
a blown turbo wouldn't make a knocking sound..
and why would your turbo blow when you are driving off boost and at like 20 km/h
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-413204
I rang a mechanic up and asked him about it, he said it sounds like the exhaust wheel has come off and is rattling around. He said it was possible that something happened while it was cooling down in my garage the night before and stuffed up when it got running that day. I don't know too muh about internals of a turbo so i'll just take his word for it as i can't get the car anywhere to get checked out. I want a bigger turbo anyway so now's as good a time as any to get one.
Hmm anyone know all the HP limits for my stock engine?
the injectors (with good fuel pump), gearbox, how much boost before its dangerous to internals etc.
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-413452
Well i must have the strongest factory RB20 turbo in OZ.
On Monday i did a little over 35 minutes (approx 28 laps) in the one session running 0.85bar of boost at Wakefield.
The car did not sit idle by the side of the track for more then 45-60 minutes without at least a 20min blast around the track. Every 7-8 laps would have to slow for a lap to get tyre temps back so the car handled reasonable.
Other then that the car was driven all day whilst shifting at about 5,500-6,000rpm, trying to get quick some consistant laps. (im only kidding myslef, my pace was far from quick, and laps far from consistant...but i was trying);)
I was oh so proud to have clocked the magical 150,000 km mark whilst on the track. The only downer on the day is that i now have an exhaust leak, from a gasket, too many sheared manifold studs???? Will have to wait and see.
But my point, the turbo is still in one piece.:P
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-414336
hhmm...I wouldn't only call one mechanic and trust what he says, especially if what he says lines him up for a job of $200 - $300 at least. I guess the easiest way to check would be to jump back in your car, warm it up and then go for a fang - if it gets on boost, then it's working, if it says well under 0 manifold pressure then it's obviously not making boost and wheel very well may have fallen off.
https://www.sau.com.au/forums/topic/19523-turbo-died-today/#findComment-415193
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
