Day preference
26 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 99
So, it looks like we will be doing the Braidwood run then.
Since it isn't too far away, we could meet at the Museum carpark at 10, leave at around 10.30 for braidwood.
This will leave us plenty of time for a relaxed look at the model shop and for lunch to settle before the drive home.
Can everyone add their name to the list to get an idea of numbers.
Donnan
So, it looks like we are going on saturday.
I had a look at the cruise routes on the ACT section of EvolutionOz (thanks for doing the hard work guys) and have narrowed it down to 2 options:
1- We do a coast run. But, for this to be fun we would have to leave here early have lunch and drive back pretty much straight after to miss the traffic.
2- We take scott's option. It is reasonably long 494km, but it looks like it could be pretty fun. I can't see that there would be too much traffic along the minor roads either. We also have the option of which direction to take it.
Canberra via Gundagai via tumut via Cooma 494 km –
http://maps.google.com.au/maps?f=d&hl=...mp;z=8&om=1
Let me know what you guys want to do. Option 2 has my vote!
Donnan
Guys i can vouch for Option 2 - :cheers: amazing!!! tight twists and long straits.... top-up fuel at Gundagai, fill up at BP in Cooma then head home...
Another time then! :w00t:
I hope to be there, depends on my car being ready, btw 98 fuel is available in Tumut. 101 is not available. Braidwood sounds good, Wood fired pizza's on a 40 degree summers day.........................yummo!!!
On another note, I can get a cooks tour of Burrinjuck wall and maybe even the power house etc [i'll have to ask and arrange etc, I work in the industry, I know the guys] if anyone is interested for a future cruise. It would be BYO meat etc BBQ lunch though, there is a shop at the park, but I don't think they are set up for lunch and coffee's etc, might get a pie and coke.
Donnan
LadyBytes
Tuk Tuk
SteadyEddie
CeJay
Shell
Frink
Bnr32t
leech_ (may leave early to get back for mates wedding)
Tarmac-
*smallprint - I'm also interested in going for a drive around the same time as everyone else to a similar/same location and grabbing some bunns I mean a bite for lunch
this sux i wanna come for a cruze but i just found out i have to work untill 1pm on saturday then i have to go to the christmas party straight arfter any chance of another cruze sunday ? :bunny: maybe it can be around canberra or just a short one i just wanna see the canberra cars or maybe like a bbq at the cotter?
and is there any car stickers for this club? that would be cool like a sau one
Edited by R33Gtst Driver
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
