Hey Guys,
Hopefully someone can help me out on this one. A couple of days ago I was driving to Fremantle when my GF said that something had dripped on her foot. At the next lights, I had a look, and it looked to be some light brown water. Just one drip. It happened again yesterday, also on her foot. (she wasn't too pleased :D)
Anyway, I'm not really sure what this is. It wasn't warm at all, so I assume its not from the engine anywhere. I suspect it may be from the drainage lines. Maybe they're blocked or something. I looked at the carpet today and noticed a small brown patch. Looks as though maybe 8 drips or so have occured. Any info you guys have would be great.
Cheers. :P
https://www.sau.com.au/forums/topic/195290-weird-problem/
Check your coolant... If you haven't been getting services done (or the past owner...) you could have a rusty heater core that's beginning to leak...
Get a pressure test done, should be able to get it done quickly and free at any workshop.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498419
That could be it actually. The previous owner never changed the coolent the whole time he owned it :P I have changed the radiator, pump, top and bottom pipe and thermostat to try and save the cooling system. I also change the coolent every few months to try and get it flushed out properly and get everything flowing.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498442
Yeah sounds like the heater cores gone alright, Ive had a few go on me over the years the puddle will get bigger as the core gets worse..
Should stink like warm coolant, replace core or disconnect and plug hoses as a temporary measure.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498636
Sounding very much like the heater core then ;)
I'm about to leave for Newman on the weekend for work, and I want to put her in for another service when I get back. Guess this is another thing on the list. Anyone know how much it costs to replace a heater core? Never had one go on me before. Just a ball park figure would be great.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3499070
I'm going to bypass it tonight. When winter comes along, I'll decide whether I want a heater or not :yes:
If I do, I'll be doing it myself. From reading the tutorials it looks annoying and time consuming, but not hard.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3500473
my heater has run out of gas and personally i dont think you'll miss a heater that much..
i had no heater all winter and it only takes about 5 minutes for your body heat to heat the car up anyway.
i'd be spending the money on something else.. coilovers perhaps?
just my 2cents worth :)
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3500975
Have your headlights run out of fluid yet?? That's another that'll get you... :)
Just remember if the cops see the bypassed heater they'll do you for it... "Must have hot air blowing on windscreen" for pits. Other option is to fit up an electric heater in the dash... Which probly ends up as much f**king around as replacing the heater core. Plus the heater core can act as a mini radiator, if you ever overheat, it could save your headgasket.
Probly sounds like I'm pro-heater, but personally, if it was me, I'd do the bypass.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3501104
Dunno about that, demister runs with the a/c.. cool air on the inside of the screen = demist...warm air = foggy.
Basically it is done by matching the internal screen temp with the outside screen temp.
So a demister can either be forced a/c or fresh outside air and should not make the car unroadworthy by bypassing the heater core.
Nothing to say your car must be warm and cosy for a roadworthy, just need a working demister, which unless he has removed the fan he'll still have.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3501139
Just to add my 2c..
You also may find it is aircon drain water which can leak back into the car via a blocked drain tube. If you run the heater/aircon on auto while driving, the aircon is on all the time.
Worth checking before you start ripping the car apart .....
Cheers
Ken
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3502208
Yeah, pretty sure you only need the fan, don't have to have the heater. If your going to do the bypass then make sure you purge the heater core of fluid first, else it will keep leaking for ages.
Go n ask the pits boys... For as long as I've been prepping cars for the pits, they've had to have heaters. I've had to fix many a coolant leak for that reason too.
Hey, they may have changed it (within the past 6 months), but I think you'll find I'm right.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3502843
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
