Hey Guys,
Hopefully someone can help me out on this one. A couple of days ago I was driving to Fremantle when my GF said that something had dripped on her foot. At the next lights, I had a look, and it looked to be some light brown water. Just one drip. It happened again yesterday, also on her foot. (she wasn't too pleased :D)
Anyway, I'm not really sure what this is. It wasn't warm at all, so I assume its not from the engine anywhere. I suspect it may be from the drainage lines. Maybe they're blocked or something. I looked at the carpet today and noticed a small brown patch. Looks as though maybe 8 drips or so have occured. Any info you guys have would be great.
Cheers. :P
https://www.sau.com.au/forums/topic/195290-weird-problem/
Check your coolant... If you haven't been getting services done (or the past owner...) you could have a rusty heater core that's beginning to leak...
Get a pressure test done, should be able to get it done quickly and free at any workshop.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498419
That could be it actually. The previous owner never changed the coolent the whole time he owned it :P I have changed the radiator, pump, top and bottom pipe and thermostat to try and save the cooling system. I also change the coolent every few months to try and get it flushed out properly and get everything flowing.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498442
Yeah sounds like the heater cores gone alright, Ive had a few go on me over the years the puddle will get bigger as the core gets worse..
Should stink like warm coolant, replace core or disconnect and plug hoses as a temporary measure.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3498636
Sounding very much like the heater core then ;)
I'm about to leave for Newman on the weekend for work, and I want to put her in for another service when I get back. Guess this is another thing on the list. Anyone know how much it costs to replace a heater core? Never had one go on me before. Just a ball park figure would be great.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3499070
I'm going to bypass it tonight. When winter comes along, I'll decide whether I want a heater or not :yes:
If I do, I'll be doing it myself. From reading the tutorials it looks annoying and time consuming, but not hard.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3500473
my heater has run out of gas and personally i dont think you'll miss a heater that much..
i had no heater all winter and it only takes about 5 minutes for your body heat to heat the car up anyway.
i'd be spending the money on something else.. coilovers perhaps?
just my 2cents worth :)
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3500975
Have your headlights run out of fluid yet?? That's another that'll get you... :)
Just remember if the cops see the bypassed heater they'll do you for it... "Must have hot air blowing on windscreen" for pits. Other option is to fit up an electric heater in the dash... Which probly ends up as much f**king around as replacing the heater core. Plus the heater core can act as a mini radiator, if you ever overheat, it could save your headgasket.
Probly sounds like I'm pro-heater, but personally, if it was me, I'd do the bypass.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3501104
Dunno about that, demister runs with the a/c.. cool air on the inside of the screen = demist...warm air = foggy.
Basically it is done by matching the internal screen temp with the outside screen temp.
So a demister can either be forced a/c or fresh outside air and should not make the car unroadworthy by bypassing the heater core.
Nothing to say your car must be warm and cosy for a roadworthy, just need a working demister, which unless he has removed the fan he'll still have.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3501139
Just to add my 2c..
You also may find it is aircon drain water which can leak back into the car via a blocked drain tube. If you run the heater/aircon on auto while driving, the aircon is on all the time.
Worth checking before you start ripping the car apart .....
Cheers
Ken
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3502208
Yeah, pretty sure you only need the fan, don't have to have the heater. If your going to do the bypass then make sure you purge the heater core of fluid first, else it will keep leaking for ages.
Go n ask the pits boys... For as long as I've been prepping cars for the pits, they've had to have heaters. I've had to fix many a coolant leak for that reason too.
Hey, they may have changed it (within the past 6 months), but I think you'll find I'm right.
https://www.sau.com.au/forums/topic/195290-weird-problem/#findComment-3502843
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
    • Yuh, My new R34 box is sitting on the workshop floor (in its large shipping box, which is a nice thing on its own), along with a front plate to convert to push clutch. There was no way I was interested in rebuilding my existing one. Was only partly interested in the risk of buying a used one. But, if you want a 2nd hander, I can point you to one in/near Melbourne at least. @Komdotkom has one that should be in good enough condition to be usable. I don't think it's in a for sale thread, you'd have to message him. @redzedhas one that definitely needs a rebuild.
    • I used to love going to Amaroo to watch the HQ series go for broke (eventually stopped due to lack of spare parts) and also the Porsche series.  It was so cool to back your car up to nearly the edge of the viewing barrier and party with your friends, having a bbq and alcoholic/non drinks. It was such a family/mates atmosphere
