thanks for your help guys.
GTST
yeah i know it has to be plumbed back.
the BOV is for my friends gtst. he just bought it (the car) series 1 r33 and it has the standard bov, but it flutters????
do some of the stardard ones flutter? cause mine dont! anyway he just wants anormal one at a decent price so i surgested the bosch one.
if his car is making a fluttering sound, then I am going to suggest that the standard bov is stuck closed, someone has put a plate under it to seal it or it is blocked of somewhere, somehow..
take the bov off, and see if you can push the piston in yourself.
if you can, then the blockage is going to be somewhere else..
maybe there is a block in the bov return line..
check those out and see what you get.
bovs don't flutter.
they CAUSE the flutter.
when they don't open due to being set too tight, the air doesn't come out of the bov and has to escape the pipes back through the turbo where it came in.
but as it passes through the turbo which is still spinning, the air gets chopped up and if you have a pod filter so that you can hear the induction sound louder, you will hear the air getting chopped up as it goes back through the turbo.
that's the ft t t t t t t t t sound you hear that you call fluttering.
which is actually called "compressor surge".
from what i have heard the flutter noise is bad,i have heard it can cause the compressor or exhaust wheel to snap off because of the force involved trying to act against the compressor??TRUE???
As for the bosh bov i would be going to a jap import parts place and getting second hand bov,The bosh is plastic and i think smaller (slightly) where as the factory skyline seems pretty durable
GTST
thanks for the info. it was helpful. i have already checked the BOV return line and it hasnt been blocked off. so next i will take the bov off to check if its working or jamed shut.
Hey ive also heard blow off valves that flutter under high boost when they shut off. Sorta like a shivering sound, what causes that then? Not realy a f-t-t-t-t-t-t but a sh-i-o-o-o-o-o-w sound :D
An example would be the supra on exvitermini.com on the dyno. Under full load, then shuts off, you hear the bov opening but instead of a constant whistle, it makes a fluttering whistle. Also on fullboost if you listen to most of the cars on this site, they do the same, and no doubt run BOV's
cool hand luke.
the supra and most VL's and so on from the fullboost site don't run bovs.
they run huge turbos and huge intercoolers with large diameter pipe work and when they back off the throttle and there is no bov, the air goes back through the turbo and so on and makes a really loud shuddering sound. the sound is also amplified by the size of the turbo and pipe work.
hope that helps.
Ok, i agree with that. What im curious is what causes cars with good BOV's to make a BOV sound but instead of a continuous one, an intermidden sound, ala fluttering. Off to4r.com i have a video of a supra that did that, and was fitted with a hks ssq bov. I know its not important or anything like that, but if it makes a sound and i could have a choice, i'd rather have the one that i like better :D
Im going with the thinking of GTST on this one. I imagine some of the bigger hp cars making those noises run the ir BOVs very tight to ensure they are not leaking under boost. (????)
That said on one of the old Serious Performance Videos (was it the first one?) Lance Warrens 20B 929 made the sweetest noises, and it ran the Racing HKS BOV.
ok.
the standard bov on a skyline or 200sx or whatever, at idle, it is open and recirculating air.
when you start to accelerate, the bov closes and then releases immediately when you back off or change gears.
the aftermarket ones that vent to atmosphere, have to stay shit at idle.
so people have to tighten it up and they often tighten it up a little more "JUST TO BE SURE" (classic).
so when driving and say you boost up to 5 psi and change gears, the bov doesn't open when you release because..
1.) the bov is too tight.
2.) the aftermarket bov springs are tighter than stock.
3.) the bov piston is bigger/heavier and is not as quick to move as the stocky.
so what happens?, the air goes back through the turbo going f ch ch ch ch ch ch
or a similar sound (depends on turbo and so on)
however, say you had the same car boost to 8psi and change gears, the bov opens but really that much and the air gets out of the bov and goes "psshh" or "squeek" as the HKS SSQV one does, but then shuts the piston down quickly due to it's tightness, so you end up hearing a sound like
psshhht ch ch ch ch
to be honest with you, I love the sound of a 180sx or 200sx which has had the bov removed completely and the holes blocked off.
sounds like a pigeon or something..
but then again, my car came with a bov, it's not leaking, it's doing it's job and sounds ok and makes my car run better so I will continue using it..
does this all make sense or am I blabbering again?
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
