Need A Couple Of Misc. Parts For My Car
Hello all as some of u know i am selling my car
http://www.skylinesaustralia.com/forums/R3...le-t195091.html
i just need a few parts to pretty it up a little... This is what i would like to get
Boot carpet and wooden support
parcel shelf - ideally with speaker covers if possible.
and just some trimmings for in the boot side walls. (pretty much any carpet that you have in your boot i want.
Its a 94 r33 4 door (not sure if the 4 door makes any difference) give me a pm or reply in here if u got anything.
I would prefer to get it from Tasmania due to postage for something like this would not be worth my while seeing as they charge per size as well as weight. anyway let me know what you all got for me..
Thanks
Ben
i have a full boot interior to suit a 2 door r33 if your interested.
sure am... i am not sure if all skylines have the grey colour carpet.. but let me know where you are and what u want for it... or just om me your number and ill give u a ring and we will work something out..
Thanks
Ben
  • 4 weeks later...
thanks for coming over guesty pity it didn't fit.. So i still need carpet for the boot, but it must come out of a 4 door r33
and wog u missed out a number in the phone number.. :)
anyway hope everyone is having a god Christmas and hope everyone has a happy new year
--Ben
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
