2007 Salvo/ns.com Xmas Cruise, Sunday Dec 2nd Meeting At 1.30pm
Hi,
There is a Salvation Army Cruise on the 2nd of December, I know that it is a ns.com cruise, but I am sure you can get over it for a good cause.
Where: ETSA PARK CAR PARK - Railway Terrace Mile End
When: Sunday 2nd December
Time: 1.30pm for a 2pm start
Please bring: A Soft or Educational Toy (plus a gold coin for the route map)
For more info : http://www.nissansilvia.com/forums/index.p...howtopic=263547
Just to clarify... Toy you bring is to give to the salvos so don't bring your favourite teddy that you don't want to let go :yes:
And as Ryan said, come on this is for a good cause.
If you need a permit let the organisers know (in the link supplied) and they will organise a notice for you.
Sorry guys I did not know you had started a thread. Yes it is a NS.com cruise but ALL are welcome !!! plus it is for a great cause.....so we hope you can join us.
The kids of Elizabeth & surrounding districts who would get stuff all for christmas, are able to list with the Salvos for a present...their situation is confirmed, then their carer/parents can attend the Salvos and pick 1 educational toy, 1 soft toy & get a food voucher. All the presents & $$$ are donated...here is a pic of our toy donations (last yr), in the foreground.
So please come bring a soft or educational toy (can be small/cheap...doesn't have to be big $$$) & a gold coin for the map or if $$ are tight...just the gold coin....SERIOUSLY it all helps.
Hope to see you there..... Quote: Any idea where and when the cruise will finish? ...definately at a watering/eating hole back in the metro area....
OLD Jules & Mark
PS ...the Playford Salvos will be attending the ETSA carpark, to collect the donations in person.
Edited by mark03
Adelaide Forecast
Issued at 5:15 am CDT on Sunday 2 December 2007
Warning Summary
Nil.
Forecast for Sunday
Cloudy periods with a possible brief light shower. Warm to hot with light to
moderate northeast to northwest winds, turning milder moderate to fresh
southwest late morning.
Precis Morning change. Possible shower.
City: Max 32
Elizabeth: Max 33
Mount Barker: Max 31
Noarlunga: Max 29
....hot but with total cloud cover....makes good cruising weather !!! Hope you can make it !!
"the OLDS aka Mark & Jules"
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
