just put a water pump in and now the car wont start. i figure its the timing. i got a timing gun but dont know how to use it on the electronic ignition or how to adjust the timing either. can anyone help. cheers jp.
https://www.sau.com.au/forums/topic/195410-r32-rb20det-timing/
  • 1 month later...
The CAS doesn't just "bolt straight back on". There are any number of threads on the subject of refitting the CAS - find them.
what i did was unbolt the whole thing from the engine block so i didn't just take off the cas i took the other thing off behind it aswell. there was no offset key so it just bolted straight off, not marking anything
to fix my problem i had to bring engine to tdc and move the cas 1 tooth at a time and start the car and repeat. took a few turns but worked incredably well. jp
