Calling My Fellow Skyliners From The Western Surburbs!
Hey mate,
I wouldn't post this up if I knew how to fix it... I know it's simple but really need some guidance...
Is there anyone from the Western suburbs that is willing to spend like 1-2 hours with me to help me fix this issue?
It'll be a good opportunity for a few people to catch up and then we go for some lunch this weekend or the next?
My just keepings stalling, and I think it's the AFM... please help... perhaps meet at my place, talk about our cars, fix my AFM issue then go to lunch which of course is my asking?
http://www.skylinesaustralia.com/forums/Fi...-s-t113284.html
Regards,
Kevin
Explain the symptoms a bit more, and people on here will be able to help pinpoint exactly whats causing the issue :)
Thanks for your willingness to help mate.
Here is the issue more in details...
http://www.skylinesaustralia.com/forums/Ca...ed-t191025.html
I am very keen to get this fixed as my Wife is going to use my car for work and if it does not get fixed... then it will be very hard for her taht's why I am very keen...
Thanks all!
u got pm. btw if it keeos stalling, do u have an atmo bov by chance? this could also be an issue
Hi mate, I've always had a HKS SSQ on my car - never had an issue until recently!!
I am betting on the AFM...
I got your PM - many thanks mate... if you could help it would be super!
Is it spluttering/cutting out then stalling?
Here is the first step: Get a can of CO contact cleaner, any repco has it, ask for it by name! When the car is dead cold(if the afm is hot it could f**k up), remove AFM, spray with CO contact cleaner, make sure it gets a good clean, alcohol based, dont touch the hot wire with any instruments, it will dry! Refit AFM, check all piping, and inlet piping, if symptoms persist which i doubt they will, refit standard BOV.
Check all wiring, especially earths. I honestly would take it too a mechanic.
The money you spend changing shit around could be spent getting it done right.
-Ryan
Edited by Ryan1600
-Ryan
Thanks for your kind words, Ryan - you're right... I have spent thousands on mods... I guess 1 more on a good service plus to fix my car won't hurt... but I would like to exhaust all avenues first before I bring it to a mechanic... what you said is good and informative... but I think I'll just make it worst if I tried...
I'll keep everyone post on what I think will happen.
Clean before buying another... no point spending money on it if it aint broke.
Thanks bro, yeah... a mate from this forum is going to help me clean my AFM and get it resoldered... if it still occurs then, then gotta buy a new one.... but thanks so much mate!
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
