  • Replies 153
lots of people run nos on the street even though it is illegal, most say as long as its not hooked up your fine unless you attract their attention...
I've stayed away from it because of the defect factor... you should be able to get away with it, it would just worry me that one day if you get a defect it means you would have to pull it all out to get rid of the defect notice.... otherwise eveyone would do it...
A good mechanic should be able to do a virtually indetectable install, along with a custom stereo will provide and area to hide the bottle... Thats how mine was anyway...
Bit if its a show car.. its lost all of its bling..
THE RESULTS ARE IN!!!!!!!!!
Ok everyone.... im pretty happy with the final results, i could have gotten more, but decided against it as i preferred to stay in the "safe" zone to begin with.
128 kW at the rear wheels without nos
and 152 kW at the rear wheels with nos.
like i said before im happy with the results, as i have stay in the safe zone.
:D
Not sure about S.A.; but in VIC if a car is caught with any part of a NOS kit installed, a fine of $2000 per cylinder applies. That's right ;) $12,000 for our cars. If this is an EPA issue (not roadworthy) then i dare say the fine applies nation wide.
Not to burst your bubble, but is 24rwkw really worth the risk? Especially when a 100% standard GTT produces that power and probably a little more. Put an exhaust, fmic, Pfc and some more boost, on a GTT, and you wont be anywhere to be seen :D .
hmmm...i would be looking carefully at the graph with the NOS
there is only a 24kw increase in peak power (which is about 32 HP)
really there should be around a 55kw increase as NOS is fairly affective at achieving the stated HP gain...
i want to see a torque curve....
umm... nitrous is basically air just with a slightly higher oxygen saturation (33% compared to ~20%ish)
regardless its still air/N2O (oxygen) under pressure being forced into the intake - doubtful that it would account for 18kw, i think the difference is mainly the dyno.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
