This was mentioned in another post but I thought it important to make a seperate issue.
I am interested to find a iPod integration solution for the bose system.
I understand the US have kits that do this, however they utilise the SAT button that we do not have.
Text appears on the factory LED display (not the LCD screen for those with the nav option).
https://www.sau.com.au/forums/topic/195456-ipod-integration/
define integration. the unit has a stacker port on the rear of it so emulation is a possibility.
I'll look into it. I need a ipod or two to fiddle with ( I don't own or want one.) to verify compatiblity
Thanks for the input jaik, however I want full control over the iPod, I don't want to be playing around whilst on the move. At any rate I cannot do the aforementioned mod that you suggested, as I do not have, nore want the factory nav.
ok for me to land that properly is $ 350 - 400 . I know of the piece you mean and I can get it locally. its the market for it that will kill the idea. if I can find something that is in the $2-300 range that works I'll do it.
I'll keep digging.
jaik,
thats what I have been doing when people ask for an Ipod. much easier.
    • If a magnet doesn’t stick to anything except another magnet then it’s not a very good magnet and is probably just a piece of steel
    • Magnetic drain plugs are fine. Just don't buy cheap shit ones. They're actually better than letting magnetic shit float around in your oil. The magnet also didn't just "fall out". OP was drilling the plug out which allowed it to come out. Even some OEM plugs are magnetic.
    • I have to say, I was briefly considering getting a magnetic drain plug but never could be bothered out of laziness/cheapness and now I'm very glad I didn't.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
