Hi guys, After blowing a turbo gasket, I’m in the process of fitting 2 stock RB20 turbos to my Nissan Syline R32 GTSt. All the work is been done at a engineering firm in Bunbury WA where my dad works.
We are making 2 separate manifolds one for each turbo. Front 3 exhaust outlets to one and the back 3 to the other turbo. There is going to be a balance pipe that goes between both manifolds to equalise pressure into both turbos. We see there is no need to have 2 wastegates so one will be blocked off. All water and oil lines are been ‘T’ . There will be 3” pipes coming off the back of the turbos converging into a 4” exhaust system. Air intake for the turbos will consist on the 1 pod filter, splitting into 2 pipes after the afm then to the turbos. The outlets for the turbos will converge into one tube entering the front mount intercooler then engine.
This project is well underway, and if all goes well will be completed in a month. Before starting this project I had 200bhp running a stock turbo with 13psi, with the intercooler and a 3” exhaust. I have had it down the drag strip with a time of 13.7 @ 167km/h.
I was interested if any one had any comments on how laggy it will be, the power output I might achieve, or any concerns about what im doing. All comments will be appreciated. thanks, Ewan.
https://www.sau.com.au/forums/topic/19547-twin-turbo-r32-gtst/
I guess the major cost in this project that would be incurred is the labour involved in engineering such a setup to work properly.
Of cos thats somewhat irrelevant here since your dad works in the firm.
For the typical enthusiast out there, such a project would not economical, since the labour cost would overwhelm everything esle.
But for someone in your shoes, i guess it would be the natural thing to do, since rb20 turbos are rather cheap, as well as the rest of the parts involved.
IMHO u might need to stick to 2 wastegates to get more accurate boost control, but i may be wrong here.
Always good to have something out of the ordinary...
do keep us updated! ;)
What 1 bar barrier? He's only using 1 turbo on 3 cylinders, which means for the same pressure, the turbo is spinning only half as fast (in theory). It's not going to be 100% efficient like that of course, but each turbo will definitely be able to run more than 1 bar of boost reliably.
That is the problem, both turbos have to run up to the original speed to generate the original boost, but now there is only half the exhaust gas volume to do it.
As a result I would expect the boost threshold to be about twice the RPM it was before. You can fix it by fitting smaller a/r turbine housings, but the top end airflow should be awsome either way.
oops nice some one actually read it he was paid in food and i kicked his ass and made him piss and im a CHICK yeh thats rite na i have to be nice hes allright but needs to put his little rotor back together as it sound strange?? at times!!(n e bunno people will know what i meen )
k
ahha mike
your car is the same as mine basically
i drive mine NORMALLY i didnt buy a skyline to thrash it qtr mile it etc
im gonna make it run good and keep the boost standard and just make it look decent
im not into this "ooh ill drag u" shit
id like my car to last and not be thrashed to the max
and maurice i couldnt care less if ya could beat me
hell a LOT of cars on the road could beat me
i dont go on as my cars sumthin special
i tell ppl
its a STOCK SKYLINE
all id have to do is spend a bit of $ like ewan did on a intercooler etc and id own u like he does
but the fact of the matter is i am not interested i got the car cause i love skylines
the end
also the 20c remark was a JOKE :)
and yeah iluvewan i know what ya mean by the rotor comment
hes gotta add some cylinders and stop making it sound like a whipper snapper ;)
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
