Hey all,
Im looking at buying some front vented gaurds that are 30mm wider than the standered ones. So im guessing my wheels now wont fill out the gaurds...
So i may look at some new wheels. What offsets and width should i be looking for?
What sort should i be looking at to fill out the gaurds more now... Want some dish... and under or around $2000...
Any help would be great..
Also looking at some rear over fenders... but how are these held on?? am looking to try and do it myself... ideas?
Edited by Adz2332
https://www.sau.com.au/forums/topic/195544-filling-out-the-gaurds/
we usually grind the rear quarter back to metal, then use 3M Automix to adhere the fibreglass directly with the exposed metal... reinforce by drilling and resining through so that the overfender doesn't move around and cause hairline cracks in the paint a couple of years down the track. If the fender allows for it we may pop rivet as well for additional reinforcement, but not where the rivet has to be covered by filler to hide it, as a couple of years down the track the filler tends to shrink around the rivets and show dimples.
3M Website for Automix
He's reffering to Front vented guards (replacement) not rear guards.
As for the front guards, it says 30mm wider, but they actually taper back into the door and the front bumper, so they are only 30mm wider at the middle of the guard then meet back to the factory bumper mounting points, its abit hard to explain, but when i had these guards on my r33, i could only space them out a extra 20mm or so, before rubbing. As for offset around +20 should do.. If using a bolt on spacer, go for the minimum size of 25mm, you should be fine, aslong as the car isn't overly low.
ahhhh pop riviting to the car.. hmmm no way you can do it without damaging panels??
Most people use this technique because it's cheap and it gives that 'tough' look to the car, but I don't think it's the look you're after.
+20? i reckon you could get away with lower than that
i had 17x8" +32 on the front of my r33, and it wasnt flush with the guards, so if you are putting on another 20-30 mm, you should be able to sneak in a gtr-ish offset rim, like +12, even if you have to add a degree of camber :)
that said, it depends on what widths you want as well..
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
