Hey all,
always loved skylines and yet couldnt seem to afford one, and being a 3rd yr panel beater i decided to get my self a reparable write off, found one at the right price from a reputable salvage dealer, got my halfcut to repair it, repaired the car and now went to get a blue slip
now even though this car was previously registed in the country and is listed on revs as a repairable write off, the guy tells me i need to have a compliance plate besides the japanese one, this car, like most of my friends imports only has the plate with a vin number starting with 6u9000 then the vechiles vin after it, and no other tags except the jap one,
now i have been told i also needed a australian complience plate to be able to get this car re registed. i know the new imports have them, yet i know my car and alot of other older imports (r32 and silvias) dont have this other complience plate only the new number pop rivited on,
so what do i need to do to get this thing registed as i know my friends have gotten things similar to this registed in the past,
i love my new car, had it repaired for a couple of weeks now and cant wait to drive it yet im stuck here.
also if ive started getting a blue slip one place, and they have said the above even though they have started to fill out the paper work can i take my car elsewhere to be passed?
if so can anyone recomend a place that can help me, im in sydney and would like the place to be within 30 min or so of hurstville
thanks
scott
https://www.sau.com.au/forums/topic/195557-registering-a-writeoff/
yeah as long as it was imported before the 15 year rule was cancelled you are fine. You need to find a blue slip place that knows what they are talking about. You will also be able to get a copy of the import approval from DOTARS if you are having trouble
depends if the car was regoed in nsw or another state. if regoed in another state and you dont already have an engineers report showing complience of the vehicle you will need to get one. a written offf vehicle check as part of the blue slip would then have to be done and then once that was all ok then you could rego the car.you dont need to have a complience plate.
thanks for your help, ill need to contact DOTARS to get the import approval, becasue the few other places i spoke to today said even though it had held registration in nsw previously i still need that documentation yet i dont need the tag
thanks
if you have proof of previous rego such as old papers you wil not need the dotars import approval copy nor will dotars give you a copy as you arnt the person who imported the vehicle originally (privacyreasons)
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
