im experiencing a shithouse feeling when im driving, the boost takes forever to come on and then its like its making a half assed attempt to do so because it makes nowhere near full boost. also when it gets to just before 6000rpm the car just pulls back on me and its all over. this has only started happening recently. shown in the photo below is a ding in the cooler piping that i think may be causing some of this but its been like that for quite some time so im led to believe its a deeper issue. only mods are FMIC, exhaust, microtech & boost raised to 12psi. any help would be greatly appreciated. cheers, mark
update: checked the vacuum line that runs from the microtech to the plenum and found this (3rd time i checked it i missed it both times
pic is a bit shite but u can clearly see the vacuum line is farked and from what id been told this was wat was causing the car to shit out so i changed the vacuum line over today and it is no better. absolutely everything seems to be fine im certain there has to be air leaking from somewhere. if the boost controller is leaking would i be able to hear the air coming out (it is only a cheapo BC)
oh and also i noticed this....
to me it looks like the gasket for the throttle body has escaped out the side or something, i dont really get it, if it has could this be the problem?
Edited by killswitch88
https://www.sau.com.au/forums/topic/195581-car-not-boosting/
what caused that ding ?? is it possible that maybe the piping itself may have developed a crack thus blowing boost out to atmoshere..I would start with all the silicon hose fittings first and then look into that ding area
one of the silicon hose fittings was farked and you could hear the car shreiking from a mile away but that is replaced and now there is no noises but yes i will double check the rest of them.
all of the silicon joiners seem fine there was a vacuum leak but i fixed that but still having the same problem. the boost gauge doesnt move into the positive til about 4500rpm and only just makes it to about 3-4 before it gets to 6000rpm and f**ks out on me.......any ideas?
ummm...no to the fcd, ive checked all the silicon and it seems to be intact, ive farked a silicon joint before but i could still make boost this mother f**ker will not get out of the negative range. how would u go about checking ignition?
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
