RB20DETT TwinTurbo2Litre
i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
sif big FMIC! Mines bigger!
I can say that Jao's car is a bit of a lag beast (from what ive seen) and traction sounded like it was an issue when he fanged it up the hill, but its cool and im shitty that he has a RB20DETT and i dont! :P
  • Replies 141
my gtr greddy manifold was modified in japan to fit an rb20 by simply welding, machining and drilling extra tangs onto the flange. the ports still line up perfectly.
ie instead of \ \ \ / / \ its now \ \ \ X X \ (yea dodgy explanation but i'm sure you get it) :D
lol, sproosy, posting again i see :)
Yea i'd love to get some help to extract every single extra kw out of this thing, as it seems to be, well, under powered, any help/ideas/places to go for help? roy? :)
LOL...I dont know. :D
I am curious to know what turbos it has...can you see any markings on the housings?
on mine? Standard 32 GT-R turbos i think, suppose i could take a sticky beak if you want.
Any suggestions on what to do next to get best gains and smooth out the power curve?
Well, call me simple minded, but R32 GTR turbos have been good for 220-230rwkws at 1 bar on plenty of GTRs...i wonder why they wont make similar power on an RB20....(note i said similar power, not the same power)??????????
Microtech LT8, they can be tuned via laptop cant they? Got a copy of your tune, what sort of ignition and fuelling does the engine have. Also have you got air temp compensation wired up and tuned for?
Id say dump the cat, and have a look at the tune. My R31 GTS-X made way more power once a decent tuner had a look at the MT8. Also have a look at your battery voltage when driving next at night. My car with the MT8 went from a pretty strong 200 odd rwkws to a doughy piece of lard as the battery voltage got into the high 11s as the ignition system gave up the ghost.
A new battery, and a big ass Bosch alternator had the thing putting the numbers down way more consistantly. Are you sure your tuner knows his way around RBs running Microtecs?
Not sure of his reputation with microtechs and RB's, it isn't a very common combination. Currently tuned by Greg at Autosport Engineering in Kirrawee (Sydney). THINKING about going to Thornleigh Cylinder Heads (huge reputation, but pricey) or UAS.
Would getting rid of the cat give any worth-while gains though? My voltage sits on around 9.9 i think(or 12.1, i really can't remember). Not sure about the air temp compensation, i'd like to look into it though as i want to explore every single possibility to extract more power out of this, long term project, hoping to crack 300+ rwkw from RB20/24(maybe).
The biggest downside at the moment is that i got the car with the microtech already in it, so i can only guess what the previous tune was, and what it has and hasn't got, so in a way, im starting from scratch, well, a more painful process.
If your battery voltage is dropping that low then i would hazard a 6 pack on the fact that your car isnt making the power it should because the ignition isnt working 100%.
The MT8 was very sensitive to battery voltage, and the igniter drivers in the ECU needed a good strong voltage, otherwise the car ran like adog. The car was always a bit doughy, the car never really made much power considering all the gear on it. Then one day i noticed on the handset at night that the voltage was lower (stereo going, lights and windscreen wipers) and the car was slower then normal.
A few questions to the right people confirmed that they need strong 12V+ voltage...the car was great once with a new battery/alternator and a good tune from Quickfit in Hornsby
so are there any other places you can reccomend to tune a microtech on an RB20 in sydney? Reasonably priced too (can't get it done yet as i just bloody forked out $1100 for work on the car including a full dyno tune :D)
I havent tried many, everyone has their favourites. But i did find Quickfit (NSW Autronic dealer) very good at getting my car to drive a lot better and make better power...cant really remember what i paid, it was 6 years ago :D
Then again, it could be tuned perfectly, and thats the power it makes?!?!?!
*shrugs* i doubt it. It runs very poorly on coldstart, i know microtechs are notorious for this, but it can't be THIS bad, i don't know, i just have my doubts, i know it can be more finely tuned, well, i have a gut feeling.
Try unigroup at girraween. They have tuned a lot of rb powered cars and offer good prices.
As the car is running, it will likely only be a bit of a touch up (depending on how the current tune looks) so you could get a surprisingly cheap quote.
 Share
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
