RB20DETT TwinTurbo2Litre
i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
sif big FMIC! Mines bigger!
I can say that Jao's car is a bit of a lag beast (from what ive seen) and traction sounded like it was an issue when he fanged it up the hill, but its cool and im shitty that he has a RB20DETT and i dont! :P
  • Replies 141
my gtr greddy manifold was modified in japan to fit an rb20 by simply welding, machining and drilling extra tangs onto the flange. the ports still line up perfectly.
ie instead of \ \ \ / / \ its now \ \ \ X X \ (yea dodgy explanation but i'm sure you get it) :D
lol, sproosy, posting again i see :)
Yea i'd love to get some help to extract every single extra kw out of this thing, as it seems to be, well, under powered, any help/ideas/places to go for help? roy? :)
LOL...I dont know. :D
I am curious to know what turbos it has...can you see any markings on the housings?
on mine? Standard 32 GT-R turbos i think, suppose i could take a sticky beak if you want.
Any suggestions on what to do next to get best gains and smooth out the power curve?
Well, call me simple minded, but R32 GTR turbos have been good for 220-230rwkws at 1 bar on plenty of GTRs...i wonder why they wont make similar power on an RB20....(note i said similar power, not the same power)??????????
Microtech LT8, they can be tuned via laptop cant they? Got a copy of your tune, what sort of ignition and fuelling does the engine have. Also have you got air temp compensation wired up and tuned for?
Id say dump the cat, and have a look at the tune. My R31 GTS-X made way more power once a decent tuner had a look at the MT8. Also have a look at your battery voltage when driving next at night. My car with the MT8 went from a pretty strong 200 odd rwkws to a doughy piece of lard as the battery voltage got into the high 11s as the ignition system gave up the ghost.
A new battery, and a big ass Bosch alternator had the thing putting the numbers down way more consistantly. Are you sure your tuner knows his way around RBs running Microtecs?
Not sure of his reputation with microtechs and RB's, it isn't a very common combination. Currently tuned by Greg at Autosport Engineering in Kirrawee (Sydney). THINKING about going to Thornleigh Cylinder Heads (huge reputation, but pricey) or UAS.
Would getting rid of the cat give any worth-while gains though? My voltage sits on around 9.9 i think(or 12.1, i really can't remember). Not sure about the air temp compensation, i'd like to look into it though as i want to explore every single possibility to extract more power out of this, long term project, hoping to crack 300+ rwkw from RB20/24(maybe).
The biggest downside at the moment is that i got the car with the microtech already in it, so i can only guess what the previous tune was, and what it has and hasn't got, so in a way, im starting from scratch, well, a more painful process.
If your battery voltage is dropping that low then i would hazard a 6 pack on the fact that your car isnt making the power it should because the ignition isnt working 100%.
The MT8 was very sensitive to battery voltage, and the igniter drivers in the ECU needed a good strong voltage, otherwise the car ran like adog. The car was always a bit doughy, the car never really made much power considering all the gear on it. Then one day i noticed on the handset at night that the voltage was lower (stereo going, lights and windscreen wipers) and the car was slower then normal.
A few questions to the right people confirmed that they need strong 12V+ voltage...the car was great once with a new battery/alternator and a good tune from Quickfit in Hornsby
so are there any other places you can reccomend to tune a microtech on an RB20 in sydney? Reasonably priced too (can't get it done yet as i just bloody forked out $1100 for work on the car including a full dyno tune :D)
I havent tried many, everyone has their favourites. But i did find Quickfit (NSW Autronic dealer) very good at getting my car to drive a lot better and make better power...cant really remember what i paid, it was 6 years ago :D
Then again, it could be tuned perfectly, and thats the power it makes?!?!?!
*shrugs* i doubt it. It runs very poorly on coldstart, i know microtechs are notorious for this, but it can't be THIS bad, i don't know, i just have my doubts, i know it can be more finely tuned, well, i have a gut feeling.
Try unigroup at girraween. They have tuned a lot of rb powered cars and offer good prices.
As the car is running, it will likely only be a bit of a touch up (depending on how the current tune looks) so you could get a surprisingly cheap quote.
 Share
    • Gosh these bmw's are worse money pits than JDM's! I won't complain about my car anymore 😂
    • I'll just leave this quick tip here after reading your joys of getting the car in the air. It should take no more then 10 minutes to get the car safely up on stands.  So for the front, jack on the tow recovery points (marked in red). Put the jack stands under the lower control arm mounting point (marked in yellow). This photo is of a R34 GTR, however the process is the same. For the rear, jack under the diff (marked in red). Put the jack stands under the rear subframe or where the lower control arm mounting point (marked in yellow). Which point you use will depend on your stand, pick a nice stable point.  You've probably already read this but it's worth repeating. When jacking up the car or using stands, stay away from the chassis rails/pinch welds. Even the factory jack point, stay away from that too unless using a factory jack. I used those jack points for years without issue until I turned into an old man and bought a QuickJack lol.
    • And this is where the leak is happening: https://www.dropbox.com/scl/fi/7h1vlmg2j5aa7rksvsjc9/IMG_9982.jpeg?rlkey=d3bnpau5f615zmxqmca0llvr7&st=kquvdxvs&dl=0   Apologies but it seems adding an image from a link does not work when the images are in Dropbox.
    • Here are some pics from the auction: https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0   https://www.dropbox.com/scl/fi/gkbfaa7urogzhyzxtdgq4/4cd77e2d-e19f-45fb-80a0-f9a88fd7f51f.jpeg?rlkey=39p7xyvgr33kj0avcjry2v4ap&st=ncxmagj4&dl=0
    • Hi all, From the western suburbs here. Just got my 2000 R34 GTT registered today! Got it imported from Japan through a mate who is doing them and managed to find a decent one. This one has only done 110,000 Km and had no body rust etc. so was very happy. I used to own a 25Gt back in 2015 (ate Ramen noodles for years to save up for it), but unfortunately, it got stolen TEN DAYS after I bought it!! Came back from Uni and the car was missing - cops found it in Springvale a month later with a lot of needles  😒 It was too late by then and I had moved on to a different car (300ZX), and after that one got broken into around 2018, I was in a very bad place and decided I would never buy a car again because it was just pointless!!! ~yeah, I have some very bad mojo~ 🥺 But now, with a stable job and a secure garage, I thought I'd get the R34 4D again but not as a daily! I love the R34s but a GTR is still a bit off my pay grade so settled for the GTT instead.    The first step for me is to get this car serviced and have all fluids, belts and spark plugs changed. I might do the brakes at one point too but atm they are fine, the fluids are what I want changed since this car probably sat in a garage for a long time. I'll then get some coilovers since the suspension needs to be changed anyway (the dust cover kit is disintegrating). I'll also upgrade my car alarm to a Viper system and then look at rims and tyres (I'm a sucker for TE37s - might have enough saved in another 3 years for that).   Today: I was planning to do the oil, coolant, air filter and fuel filter change this week. Started on the oil change today and MY GOD what a pain!! I used to think the 300ZX engine bay was cramped - oh I was so wrong! 😂 I've done the usual services on my cars before so it was not like I was going in blind. I looked up all the forum details about what oils to use, what coolant to use, what points to use to jack the car or place stands etc but I did not expect it to be this hard. Long story short - all I managed to do was the oil and filter change. I think I might end up taking it to a mechanic for a coolant change because my SCA stands and trolley jack just can't get far enough underneath to the cross-member and I don't want to be crushed under my favourite car....yet. Side note: In Dandenong, there used to be a shop that lets you hire their hoists - does anyone know if they have those around? I can't seem to find the Dandenong place anymore. I contacted them off FB almost 6 years ago and I'm not in it now. If anyone know of one, that would save me some time going to a mechanic for the basic services. Oil: Dark and gooey but no metal pieces. Oil Filter: Was a b***h to take off but no red flags Air filter: Yucky! Was black (Smells like fuel which makes me think it may have been running rich? - am I way off?)   Concerns: I have but one concern atm and that is that there was a very small amount of oil leaking where the engine and the transmission connect (Automatic). It may be the rear seal? It's not a massive leak and it does not affect the oil pressures or leak oil all along the driveway. It's been falling into the cover this whole time. I've taken the cover off so I can check the garage floor from time to time.  I also have not seen my engine temperature gauge ever sit at cold and slowly move up to the right spot, but that might be because every time I saw the car today, it was running. I'll check that again tomorrow. ATM it just sits right in the middle. I may just be paranoid but I don't want an overheating engine while my gauges say everything is fine. 🙈 Other than that, I'm very happy with the car! Feels like it's about time I went back to spending my weekends driving or cutting my arm on stupid sh*t in the engine bay.   PS: I will post a pic later on because I underestimated soooo badly today and it was dark by the time I finished! PPS: I broke the two damn plastic pins that hold the intake funnel section to the front bar. This is the piece made to bring cold air to the airbox. The connection to the airbox is fone, but the two clips just broke off! Should I be worried? Anyone else done that?
