  • Replies 141
A guy we know on the Coast hat a RB20DETT and it bascially went like a bag of crap.....it looks to be a waste of money if u dont upgrade the engine example.....stroker kit at least.....or rb30 bottem end.
The simple fact was....in this case.....the this car im talking about went like a bucket of crap...i hope urs works out better.
It came from japan with the twin turbo setup. so it was all done good!
- Luke
hmmm...not parallel turbo setup ..but sequential. The guy on the coast with TT setup. Which two turbos were being used? Like I've been saying, im in Jamaica.... RB30 are NOT a dime a dozen around here :D . YES I know that its not the best bang for buck and NO I'm not trying to fool ppl into thinking i have a GTR :) . I just wanted a different approach on the tuning methods....so CT12s....ae these Turbo starlet turbo...how about that for use.
If used in combination with the Tomei 2.4L stroker kit, what then?
Does anyone have any experience with this setup? Meggala..where are you?
edit: hey...where's my medal for the almost 3 yr old thread resurrection <_<
Edited by 5hift
I don't know what kind of power they can handle, the 1GGTE's aren't that great an engine so I don't think people have done loads to them - all I know is they work on a 2L.. maybe CT12A's from a 1JZ - they handle 280hp stock so they musn't be too bad.. But then again if you are going to increase the capacity of the engine you might as well use GTR turbos...
Something like this.
While rb30's may be rare in jamacia, freighting a turbo (or two) is probably a good option.
rb26 twin turbos will (according to my understanding) spool faster than an rb25 turbo AND push more air.
and they have a combined capacity of 2.6L, not 4.0L.
Unless you can figure out how to get more air in at lower rpm (I vote suprecharger - but then 3 induction aides...?)
I guess at the end of the day you would want something close to 3L worth of (two) turbo(s) (according to the factory) that will still bolt on.
Well, thats my uneducated opinion. good luck with the venture. Since you have the gear, I think you should just stick them on.
But if you wind up the boost, you will probably run lean.
good luck
Josh what I mean is for the same effort a better and simpler solution may be had .
I'm not against people trying things that may not have been done before but for me the end result needs to be good to justify the effort .
For me the drama with RB20's is that good torque is difficult to achieve without a peakier power curve than I want . I reckon the cheapest RB to buy is an RB30 SOHC and the ET exhaust manifold is (should be) easy to get . For power and torque on a budget a second series NA RB30 is hard to beat - depending on the expectations .
Turbos - could be an expensive suck it and see debacle . If I could find them the G11 Charade could be worth a look . Otherwise maybe Garrett T2's or small T25's . Garrett T28's off a GTR with smaller trim compressors may bring it on in similar fashion to a GTR . These use exhaust housings of compact dimensions because this set up is rather crowded on an RB26 . If you can use these housings and dump pipes it would save lots of time over custom fabrications .
Twins will have a weight penalty over a reasonably sized single .
Gotta go , cheers from Goulburn A .
Yeh thats what I was thinking - If worthwhile gains to be had were there, then yeah go for it - definately.
Respec guys...I'll be sure to let you know if i pursue this buildup. Now im going to go find out if 26 Manifold will fit the RB20 ;)
Unfortunately it doesn't. the bolt pattern is different.
This may sound silly but is there enough meat in the head casting to drill and tap alternative stud holes ? I'd really like to know this myself because RB20/25 HKS cast low mount manifolds are easy to get compared to the rare RB26 version and I want to use the 26 head . Long shot I know but sometimes these things work .
Cheers A .
Rips (Rotorua Import Pro Shop) on this forum (and SDU) makes an adaptor plate which lets you bolt up the rb26 stuff to rb25 heads
edit/ he may also make a adaptor for fitting rb25 to rb26. Find his email and ask him :)
Edited by Bl4cK32
Hi guys, After blowing a turbo gasket, I’m in the process of fitting 2 stock RB20 turbos to my Nissan Syline R32 GTSt. All the work is been done at a engineering firm in Bunbury WA where my dad works.
We are making 2 separate manifolds one for each turbo. Front 3 exhaust outlets to one and the back 3 to the other turbo. There is going to be a balance pipe that goes between both manifolds to equalise pressure into both turbos. We see there is no need to have 2 wastegates so one will be blocked off. All water and oil lines are been ‘T’ . There will be 3” pipes coming off the back of the turbos converging into a 4” exhaust system. Air intake for the turbos will consist on the 1 pod filter, splitting into 2 pipes after the afm then to the turbos. The outlets for the turbos will converge into one tube entering the front mount intercooler then engine.
This project is well underway, and if all goes well will be completed in a month. Before starting this project I had 200bhp running a stock turbo with 13psi, with the intercooler and a 3” exhaust. I have had it down the drag strip with a time of 13.7 @ 167km/h.
I was interested if any one had any comments on how laggy it will be, the power output I might achieve, or any concerns about what im doing. All comments will be appreciated. thanks, Ewan.
I'm running an RB20DETT setup at the moment using twin T28 turbos.
Lag, well, very considerable. At 9psi, i was hitting full boost at around 4500-5000rpm, now im running 13psi boost and making peak power at 7000rpm...
i GUARANTEE you you will NOT make 280rwkw without some serious headwork and bottom end work, not on an RB20 anyway.
As for manifolds, im using RB26 ones, just using a custom fabricated adaptor/spacer plate blah blah blah, allot of custom stuff
What else have you got done to your car??? I would have thought that if a std RB20DET running the factory turbo can make 160odd rwkws at 14psi, and with a std R33 turbo they can make approx 180rwkws at 14psi...
That with 13psi out of a twin T28 setup you should be making considerably more power then what you are making. What injectors/fuel pump are you running, exhaust, intercooler, cat...i recall reading you are running a Microtech...what did the tuner say was limiting the power???
i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
