i have a big FMIC, 700hp fuel pump, GTR injectors, custom piping, custom exhaust with split dumps off each turbo, running into a 3" system, through a 3" hi flow cat, adjustable fuel pressure reg, microtech LT8 with handset.
i think he said boost, if i wanted 200rwkw he said u'd need much more boost *shrugs*, lol. At the moment i can't really afford another re-tune so im stuck.
sif big FMIC! Mines bigger!
I can say that Jao's car is a bit of a lag beast (from what ive seen) and traction sounded like it was an issue when he fanged it up the hill, but its cool and im shitty that he has a RB20DETT and i dont! :P
  • Replies 141
my gtr greddy manifold was modified in japan to fit an rb20 by simply welding, machining and drilling extra tangs onto the flange. the ports still line up perfectly.
ie instead of \ \ \ / / \ its now \ \ \ X X \ (yea dodgy explanation but i'm sure you get it) :D
lol, sproosy, posting again i see :)
Yea i'd love to get some help to extract every single extra kw out of this thing, as it seems to be, well, under powered, any help/ideas/places to go for help? roy? :)
LOL...I dont know. :D
I am curious to know what turbos it has...can you see any markings on the housings?
on mine? Standard 32 GT-R turbos i think, suppose i could take a sticky beak if you want.
Any suggestions on what to do next to get best gains and smooth out the power curve?
Well, call me simple minded, but R32 GTR turbos have been good for 220-230rwkws at 1 bar on plenty of GTRs...i wonder why they wont make similar power on an RB20....(note i said similar power, not the same power)??????????
Microtech LT8, they can be tuned via laptop cant they? Got a copy of your tune, what sort of ignition and fuelling does the engine have. Also have you got air temp compensation wired up and tuned for?
Id say dump the cat, and have a look at the tune. My R31 GTS-X made way more power once a decent tuner had a look at the MT8. Also have a look at your battery voltage when driving next at night. My car with the MT8 went from a pretty strong 200 odd rwkws to a doughy piece of lard as the battery voltage got into the high 11s as the ignition system gave up the ghost.
A new battery, and a big ass Bosch alternator had the thing putting the numbers down way more consistantly. Are you sure your tuner knows his way around RBs running Microtecs?
Not sure of his reputation with microtechs and RB's, it isn't a very common combination. Currently tuned by Greg at Autosport Engineering in Kirrawee (Sydney). THINKING about going to Thornleigh Cylinder Heads (huge reputation, but pricey) or UAS.
Would getting rid of the cat give any worth-while gains though? My voltage sits on around 9.9 i think(or 12.1, i really can't remember). Not sure about the air temp compensation, i'd like to look into it though as i want to explore every single possibility to extract more power out of this, long term project, hoping to crack 300+ rwkw from RB20/24(maybe).
The biggest downside at the moment is that i got the car with the microtech already in it, so i can only guess what the previous tune was, and what it has and hasn't got, so in a way, im starting from scratch, well, a more painful process.
If your battery voltage is dropping that low then i would hazard a 6 pack on the fact that your car isnt making the power it should because the ignition isnt working 100%.
The MT8 was very sensitive to battery voltage, and the igniter drivers in the ECU needed a good strong voltage, otherwise the car ran like adog. The car was always a bit doughy, the car never really made much power considering all the gear on it. Then one day i noticed on the handset at night that the voltage was lower (stereo going, lights and windscreen wipers) and the car was slower then normal.
A few questions to the right people confirmed that they need strong 12V+ voltage...the car was great once with a new battery/alternator and a good tune from Quickfit in Hornsby
so are there any other places you can reccomend to tune a microtech on an RB20 in sydney? Reasonably priced too (can't get it done yet as i just bloody forked out $1100 for work on the car including a full dyno tune :D)
I havent tried many, everyone has their favourites. But i did find Quickfit (NSW Autronic dealer) very good at getting my car to drive a lot better and make better power...cant really remember what i paid, it was 6 years ago :D
Then again, it could be tuned perfectly, and thats the power it makes?!?!?!
*shrugs* i doubt it. It runs very poorly on coldstart, i know microtechs are notorious for this, but it can't be THIS bad, i don't know, i just have my doubts, i know it can be more finely tuned, well, i have a gut feeling.
Try unigroup at girraween. They have tuned a lot of rb powered cars and offer good prices.
As the car is running, it will likely only be a bit of a touch up (depending on how the current tune looks) so you could get a surprisingly cheap quote.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
