That's a difficult one because the "affordable" twin scroll integrally waste gated turbos intended for 2-2.5L Subaru's and Evolution Lancers won't bolt up . To make either of those work would mean a one off exhaust manifold because their wacky mounting flange design is so different to the std Nissan manifolds one .
Its really hard to have a win here because no one appears to make a twin scroll integral waste gate turbine housing that fits a split pulsed T3 flange size . You can get a few twin scroll housings without waste gates but to apply external/s is difficult and expensive to do properly . I can see 6-7G's worth of bits (still in boxes) and for that kind of money you may as well fit an RB25DET and gearbox with less exotic bolt on turbos . Some may even suggest selling the R32 and buying an early reasonable nick R33 . I once wanted a powered up R32 but opted for an R33GTST because most of the basis for a good road car is already there - turn key operation .
Performance road cars make you want to tear your hair out , you have to be so careful that you don't paint yourself into corners by spending lots without getting the performance benefits . Years ago I was told that factory engineering is hard to beat on price , the more goodies you can get in std trim the better because the manufacture has done all the hard work for you . BTW I'm not sold on GTR's because they are so complex expensive and heavy for the engine size .
Cheers A .
  • Replies 141
my mate recently came back from QL with the gold twin turbo rb20 laurel
seems to go ok had to do a quick fix on the ecu and use my tomei remap to get it running better
The standard ecu didnt like q45 afm and gtr inj, lucky the remap was for 555cc inj, z32 and trust td06 19c
so it idle's and runs well enough for him to take it to the track for sat drift prac
it will be good to see it once its had a tune
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
