Hey Guys, just got an R32 RB20DET 1/2 cut to do a conversion into my 180sx. It arrived and is in VERY good condition!!
I already had a gearbox, will now have one spare so will be selling it all as a manual conversion package. Unless the price is right...
Below are pics of what there is... Basically I am removing engine package and brakes. Everything else is up for sale.
All Items come from this nice, clean R32GTS-t Half cut... Genuine 80,000kms – With Exception to the obvious (I.e. 180sx bits)
Stock Front bar (Average Condition) – Pickup Only - $10
Glovebox – $20 Pickup or $40 Posted
Instrument Cluster (Just under 80,000km) – $50 Pickup or $70 Posted
Thermo Fan – $15 pickup or $35 Posted
Washer Bottle – $15 Pickup or $30 Posted
Engine Fan – $20 Pickup or $40 Posted
Stock Intercooler (no piping) – $20 Pickup or $40 Posted
Aircon Condenser – Pickup Only $20
Climate Control Unit – $40 Pickup or $50 Posted
Steering Wheel (Shithouse Condition – No Horn Button) – Free Pickup or $20 Posted
ABS Controller Unit – $50 Pickup or $70 Posted
Front ABS Senders/Sensors – $20 Pickup or $30 Posted
Aircon Bottle/Canister – $20 Pickup or $30 Posted
Front Wiper Motor – $10 Pickup or $20 Posted
Kick Panels – $10 each Pickup or $20 each Posted ($30 for the pair Posted)
Empty Front Cut – Pickup Only – Free
Dash (Average Condition) – Pickup Only - $10
Aircon Compressor – Prefer Pickup - $30
Front Sway Bar – Pickup Only - $10
Bonnet Catch Etc – $20 Pickup or $30 Posted
180sx Hatch Brake Light – $10 Pickup or $20 Posted
180sx Mirrors – $30 Pickup or $50 Posted
180sx Front Indicators – $15 Pickup or $25 Posted
R32 Skyline Gauge Holders (One Damaged – as in Pic and Other Brand New – Purchased off Ebay and never fitted. Looks the same, may need trimming) – $30 for the pair Pickup or $50 for the pair Posted
Well, as you can imagine, this has taken me quite a while!!
You are best to PM, SMS or Give me a call.
Thanks,
Todd
Ph: 0400 113 776
Edited by CATKICKER
https://www.sau.com.au/forums/topic/195607-r32-gts-t-halfcut-cleanout-more/
HUGE UPDATE IN THE FIRST POST AND HERE!
R32 GTS-t Manual Conversion Package
Includes:
RB25DE 5sp Gearbox (80,000kms) – Same as RB20DET
Used Factory Clutch Kit
Rubber Shift Boot
Flywheel
Clutch Pedal
Brake Pedal
Clutch Master Cylinder + Lines
Clutch Slave Cylinder
Instrument Cluster Surround
Centre Console Surround with Gear boot
All Nuts, Bolt Etc
PLEASE LET ME KNOW IF I AM MISSING ANYTHING THAT IS REQUIRED
Price $900 FIRM, Prefer Pickup but will pack and ship on pallet if buyer organises and pays freight.
WILL SELL BOX ALONE FOR $600 FIRM
Thanks,
Todd
Ph: 0400 113 776
Edited by CATKICKER
hey todd, ure a bloody hard bloke to get a hold of over the phone! noticed you only had $10 on the stock bar, how much on the reo ....? (I can view the pics, but how pushed in is the bar? bit more than love taps or not?? I'll freight it up here to me, can have it picked up from ure house, Damo
Edited by madaz R33
  • 1 month later...
hey Todd, intereseted in a price for the centre surround console and gear boot cover, this prob doesnt make sense but also want the inner console piece to go with the centre surround console,
thanx Damo
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
    • Thanks Duncan, I don't have a GTR these days mate. Gone soft..
    • Yeah. air pressure leakdown test is where I would be headed next here, using one's ears to determine whether it's the valves or bores/rings leaking...
    • More likely you didn't bed the rings in correctly and have glazed the bores. Running with misfires on a fresh build is somewhat of a no-no. Surely no-one "smoke tests" the combustion chamber? That's what a leakdown test is for. Smoke testing is, um, a bit of a wank at best, and only really useful for external pipework.
    • Well, obviously that kit is not a relocation kit or anything other than just the original isolators and the like. I would suggest that it should be a matter of just bending up some flat bar to build a mount over the top of some other diff, with the flat bar held to the back of the diff by the rear hat bolts. A little welding, a little thinking about how to secure the front of this structure, maybe some different hoses in case you can't get it in just the right place.
