dood send me pm the aircon vent on passenger side and im also after the front left hand side indicater if possible shot gun those items for me :D
dood send me pm the aircon vent on passenger side and im also after the front left hand side indicater if possible shot gun those items for me :thumbsup:
Sorry mate, it is shagged.
Whats the ABS pump goin for?
The price is with the pic mate... $50 Pickup or $70 posted (Cheap!)
PM sent.
PM Replied!
Hey,
I'm just interested. Did you still have that R32 Front cut (shell only)? If I organise someone to come pick it up will you let me (a frieght company) as I need entire front end frame and bumper support.
Cheers!
Paul
Hey.
I managed to get a price on the freight...scary...about $750 due to the going over water bit....so a bit out of my price range unfortunatly. :D
Anyway Just wondering if you still have the washer bottle, if so send me your bank details and I'll buy it.
Cheers!
Edited by Helious
would these 180sx side mirrors fit my r32 gts-t 93 model??
if so consider em sold. and pm me with bank details??
Edited by allthewaytotheskyline
  • 3 weeks later...
  • 3 weeks later...
Hello again,
Did you have that washer bottle at all? Also did u have a pair of GTR r32 indicators lying around, or know someone who does as I need a pair asap.
Cheers!
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
