I Live in MEDOWIE,. Just north of NEWCASTLE, NSW
0401 148 767
GENUINE INQUIRIES ONLY.
NO TIME WASTERS, PLEASE.
INTERIOR;
GTR R32 Front drivers seat for $300,
Fixed back BRIDE racing seat, Carbon re-inforced just retrimmed, side mounting set-up $700,
GTR R32 passenger door trim $150,
rear lower interior trims 2x GTR and 2x GTS $70 each,
r32 coupe' floor carpet x 2 $80 each,
GTR R32 hood lining x 2 $80 each,
R32 instrument cluster surrounds with switches x3 $80 each,
Dash Facias, GTR and GTS x 3 $70 each
R32 boot and fuel cable $45
2 x steering columns $60 each,
R32 bonnet cable $30
Air conditioning parts, vent motors $30, electronic control moduals $150, ducting under dash $15, sensors $20 each.
Std GTR P/S, 4WD computers and amps that sit under the parcel shelf, $ 50 each
STD R32 GTR computer and chipped GTR computer, $100 std and $200 chipped
MECHANICAL
R32, 33 and 34 GTR TOMIE intake piping with K&N filters, $300 the lot,
R32 GTR STD CRANK, $350
Stainless steel 3 inch one piece $450 (nice gold colour now) picture below
std Nissan pipes $30 each,
std plastic GTR BOV return pipe $50.
Item: 5 speed R32 GTR Gearbox and transfer case. Price: $950 ono
ATTESSA control solinoides, the front mounted ones and one rear mounted one, $100 each
2x R32 GTR TURBO's High flowed for 350hp, Hi flowed by MTQ (old Turbo Torque at Archerfield, QLD), with largest ompressor and metal turbine wheels you could fit at the time of rebuild, improved bearings, new everything and in perfect condition. rebuilt in 2003, wrapped up in plastic and preserved from moisture and dirt and checked regularly.
both are in brand new condition, used only for 2 mins to find out that the oil ring on No6 cylinder had broken, then taken off and never fitted again to anything! $2000 neg on this item, as they cost $2300 just to highflow and rebuild
Turbos also come with Exotic Exhaust custom made stainless headers ( i think they are about 2 1/4 inch dia), and std GTR dump pipes, and std wastgate actuators.
BRAKES
$100 for brake boosters each (tested and not leaking), and $100 each for the clutch boosters, brake master cylinders $100, clutch master cylinders $100
2 x 300 zx twin turbo front calipers, 2 x R32 GTR front calipers and 4 x GTR rear calipers. Price: $700 the lot for GTR front and rear calipers, and $400 the 300zx fronts
EXTERIOR
R32 GTR Trust Gracer side and rear aero trimings, genuine original item, paid over $1500 for the lot new, sell the lot for $650. or $450 sides and $200 rear
R32 GTR front guards in perfect condition still on road car for $650 pair or $350 each, or slightly damaged GTR alloy guards $100 each. Repairable. a lot cheaper then new, if you can get them still ??
SUSPENSION
R32 gtr gts4 upper and lower suspension control arms front and rear, front lower arms $50, rear upper $100 each ONO, front caster arms for GTR and GTS4 $60 each,
TIRES
2 x 275/40/17 Goodyear Eagle F1 GS DOT 6mm tread $300 pair,
2 x 255/40/17 Yokohama DNA GP E-Spec DOT 6mm tread $300 pair
2 x 315/35/17 Yokohama semi slicks. (sticky) 3mm tread $250 pair
WHEELS
2 x 17x 8.5 Manaray one piece rims (silver ones) off set =33 $300 pair won't fit over Brembos
2 x 16 x 8 Melbar GG7 very light weight rims (grey ones) off set = ? fitted a r32 gts with Mickey Thompsons on them $250 for the pair
1 x 17 x 8 Volk Challenge F-Zero off set = 33 with 245/45/17 Dunlop Formula FM901 tyre with 7mm tread $200 ono
rb26sparecranklc3.th.jpg cheap stroker kit for RB25
Does anyone have one of these rims lying around????
Size is 17 x 9, offset = 32 for a R32/33 GTR
If you are looking for any small, or hard to find items for a R32 GTR/S, that you can't find at wreckers or is lost or broken, then i might have it as i am a bit of a horder. Give me a call or PM me explaining what you need as i have a lot of extra stuff that is hard to find or expencive to replace.
Hope i can help any of you with any problems or queries.
Keep the Pm's coming as i am needing to find homes for the things that i no longer need. All items were kept for spares for my car, now i've taken it off the road, i no longer need them.
CHEERS
JETMAN
Edited by jetman
  • Replies 48
do u have plastic surround on the steering wheel.. only need the bottom bit which fits the ignition barrel
Hi Mate
The whole surround for $10. where are you located as postage might cost about $9.
If you are local, Bne then you can pick up ASAP!!!!!
jet man Bro!!
The two Fuses/Relays On the GTR ABS Unit in the black box??? Willing to part with them???
That would render the ABS unit U/S. if they where taken out, I'll sell you one of the units for $80 plus delivery if that will get you out of trouble.
Hope this helps
front reo bar undamaged?
passenger side vent?
r32 gtr master cylinder?
You can have the vent for free as it's slightly damaged and have the R32 GTR master cylinder for $170, pick up or plus delivery.
Edited by jetman
do you have both demister airvents? (located on the top of the dash near the windscreen)
I have both front windscreen vents in great condition with clips, only slight problem is the postage. I'm after $20 for both but the postage to Melbourne will be $10 parcle post if it fits. The length of the longest one might not fit in a parcel post bag with protection around it. I'll look it up tomorrow and see if we need to send it in a carboard tube.
Any idea if its the ZEXEL type air con compressor??
I'll check for you tomorrow.
sorry champ
A/C compressor sold.
Edited by jetman
  • 1 month later...
price adjusted and new address added.
Happy New Year to all
Hi,
I'm after the ash tray if you have it. I need one to cut up for a data logger instalation.
Regards
Andrew
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
