Hi Everyone,
Well while I was 600km from home I had a heater hose leak (R33 gtst). I made a bypass and have made it home, all good, no overheating issues.
Now, I guess it is time to replace as many hoses as possible in the cooling system. So how many hoses are there and where do I get all these parts from?
Can anyone tell me the part numbers for the heater hoses and any other necessary Nissan parts?
I will replace as much straight/small hoses with Pirtek generic hose I guess. And the radiator must need replacing too, so I guess I'll get one of those Mspec ones?
Anybody done this to an R33 GTST and can help me out with some advice? Is there a kit and a Nissan part number?
Edited by simpletool
https://www.sau.com.au/forums/topic/195621-cooling-system-hoses/
So far I have found:
Heater hoses (4) in silicon by samco (UK) for R33/R34 and R32 GTR. Worth a look if you want quality.
Ebay also has a 14 piece kit for the GTR (includes oil, air and water lines). But quality could be a bit unknown for pressure.
I am in contact with Nissan atm, will give part numbers when I get them.
This is on my to do list as well, dammit, that list is so long.
Gates Racing make very good quality hoses, I have used them on other cars and they are much better than the stock ones, they tend not to go all soft and loose around fittings after time like other hoses do. I'm not sure about them making the heater hoses though, I know they make the main ones.
But Samco only make for GTR, pity.
I've got a pic of the heater and cooling systems from Nissan, I will upload tonight or tomorrow.
Got 2 heater hoses and the white plastic 4-way joiner thing on the firewall on order.
I will also get Gates radiator pipes and the Mspec radiator. I will replace the other hoses next year - hopefully by then someone will make a silcon kit or something. Surely there are hundreds of R33 GTST owners out there who must be so close to needing new hoses, mine is a late 96 and it's time. What about those older car owners?
I did this very thing on my gtst. I had one of the rad hoses let go and figured they were all the same age and didn't want a coolant hose to keep leaking every second week.
I simply went to nissan (brighton here in Melb) and said I want every coolant hose replaced....they did all the hard work sourcing the hoses (no kit, although some hoses come in pairs etc). This was about 3 years ago so I don't have the receipt but from memory it cost around the 800 mark for all the hoses and clamps + labour to get them done. Not cheap but gave me piece of mind and I never had another problem.
Oh yeah and I'd def go genuine hoses as they are rated to pressures and temps. Other non genuine hoses NEVER seem to last as long as the genuine items.
Here are the diagrams as promised for R33 Series 2 - RB25DET
Heater Hoses:
Coolant Hoses:
Part numbers can be hard to make out, but these were supplied to my by Nissan parts person. There are prefix number to be attached to these, but now you can see what they see when looking for your parts.
The thing in the top corner of the heater hoses is the white plastic part that goes on the firewall - I got a new one of these today.
  • Like 1
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
