Hi
im pretty new to the whole turbo world.
I have a Series 2 R33 GTST with pod filter, catback exhaust and turbotech boost controller.
I am running 12 psi and decided to perform a modification that was feature in the latest High Performance Imports magazine.
The modification involved cutting out 1 inch of the rubber intake pipe and installing a metal pipe in place of the rubber that was removed. This was done to ensure the rubber pipe stays all the way open during boost. According to HPI under high boost the rubber intake pipe can occassionally suck in on its self during high amounts of boost resulting in lost power.
Anyway.
As i am driving and hold my foot flat to the floor i hit 13psi and the car just backs off all of a sudden it scares the shit outta me.
What have i done??
Is this the wastegate opening??
I know the boost im running isnt safe, but if only hit 13psi twice and the car has lost all power both times. At the moment im trying to drive it on vacuum until my mechanic down tunes the boost to 10psi.
Does anyone know what i have done wrong??
Thanks
You are hitting rich and retard. The ECU richens the fuel mix and retards the timing, so you dont damage the engine. Run 10psi, much safer.
Edited by stolen_s15
EDIT - beaten to it..
it's not about safe.
it's about airflow.
R33 and over 10psi of airflow on stock ecu = rich and retard which you will feel as a bad missfire/power loss/jerking type thing.
with the FMIC it will be worse.
the air will be cooler therefore more dense which will mean it will cut out at lower revs say about "4500rpm"
you need some sort of ecu controling thing.
Cheap = SAFC
expensive and better = aftermarket programable ECU (Power FC, MICROGUESS, WOLF, etc etc)
Edited by GTST
i hit R&R the other day for the first time when i installed an tuned my ebc. freaks you out abit hey...ha i run mine on 11psi which i find safe.
yeah, it scared the absolute shit out of me.
I thought they didnt make SAFC's anymore?
might just need to get a second hand one if thats the case.
considering there is metal reinforcing on the rb25 intake pipe as it is you'd have to be running a LOT of boost...
I have seen one do it with only 260rwkw, took ages trying to work it out on the road, but a good tuner shoudl diagnose ti pretty quick on a dyno.
ive found that every s and r series turbo car has the reinforcement inside the intake pipr, its not a steel tube if that what your looking for, its just a spring that winds itself arount the intake pipe
Mate of mine has a drift R32 2 door with a 25 in it and found a major power drop one night at a drift prac.... pulled into the pits and while free revving the engine the intake pipe was sucking closed.... they had a look at the pod air filter which was almost black it was that dirty... blew some compressed air through it and all was sweet again. only making 220 rwkw on 1.1 bar too so power is not so much a factor with the stock intake pipe
hmmm maybe someone took mine out, it had a pod on it when i bought it, definitely nothing in there like a spring.
I might give the steel pipe insert a crack for something to do
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
