I've sold my beloved beast so now i need to clear out my garage! I need to get rid of all this stuff. most prices are totally open to offers!
LOCATED IN SYDNEY, NORTHERN BEACHES
will post at buyers expense BUT PLEASE NOTE: anything you want posted i'll have to put another $10 on the price for the time and effort it takes to wrap box and get this shit to the post office. ONLY CAUS THE PRICES ARE ALREADY SO LOW ITS THE ONLY THING THAT MAKES IT WORTH POSTING!!!!!!!!!!!!!!!
PM or call me - 0410 321 343
Cheers,
Row
GTR Style Front Bar:
BRAND NEW STILL IN PLASTIC bought from UAS for $550 (thats the price they are everywhere and then realised my cooler piping was in the way. The image isn't my bar BUT its exactly what mine looks like.
PRICE DROPPED TO $350!!!!! what a discount for something that is BRAND NEW!
PARTS FROM AN ECCS SILVER TOP RB20
Intake Manifold lower half:
Complete, comes with 6 injectors, fuel rail, little JECS controller and stock fuel pressure reg and all other electric gizmos Its in good condition, came from an engine i bought to replace my old one. Perfect for using to design a forward facing manifold for your RB20 while keeping your car on the road. (the top half is gone but this is the only pic i have)
Well cheap at $20!!
Stock exhaust manifold and heat sheild $10:
The manifold is in good condition but the heat shield has a little surface rust on it. Good if you're looking to turn your car back to stock for sale.
Cheap as at $10
Stock sump:
Will fit other RB engines, good to turn 4WD blocks into RWD. needs a clean is all
SOLD
Oil Dip Stick:
good condition $5
Water Pump:
Good condition, came off the doner engine which had around 80thou ks has been sitting around for a while though so needs a clean and an oil. (Cam gears have been sold!)
$10
Air-con condensor pump thing:
Calsonic type with the pully and clutch and little pipes coming out of it (been told these are worth about 100 from wreckers etc)
$20!!
ALSO
Machined Rb26 & Internals
All this stuff was completely machined for a rebuild with forged pistons so its all in very good condition but has been in storage for a while, hence the covering of oil to prevent surface rust, so it needs a clean. The low prices reflect the fact that now without a project to put it all in i want this stuff gone! open to reasonable offers
R32 Block, crank and cradle:
lined bored for this crank and cradle and honed to 87mm, crank machined for rebuild, reground contact surfaces, perfectly straight, all parts crack tested and came up 100% ok, all parts pressure washed - $1500 neg
Rods:
machined for rebuild, all contact surfaces reground, crack tested - 100% good - and pressure washed - $150 neg
for more info & pics pm me or see my other post for 'Machined RB26 block and internals'. selling at a massive loss
Edited by Black Betty
https://www.sau.com.au/forums/topic/195660-delete-me/
  • 4 weeks later...
Has the bar been trial fitted to a GTSt? I need an assurance that it does not require modification to fit a GTSt, otherwise the panel beater is going to charge me uber dollars to cut and modify to suit my car :(
absolutely sure it is made to fit an R32 GTS-t
Bought it from UAS as 'GTR style bar to fit GTS-t'.
https://www.sau.com.au/forums/topic/195660-delete-me/#findComment-3671225
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
