I've sold my beloved beast so now i need to clear out my garage! I need to get rid of all this stuff. most prices are totally open to offers!
LOCATED IN SYDNEY, NORTHERN BEACHES
will post at buyers expense BUT PLEASE NOTE: anything you want posted i'll have to put another $10 on the price for the time and effort it takes to wrap box and get this shit to the post office. ONLY CAUS THE PRICES ARE ALREADY SO LOW ITS THE ONLY THING THAT MAKES IT WORTH POSTING!!!!!!!!!!!!!!!
PM or call me - 0410 321 343
Cheers,
Row
GTR Style Front Bar:
BRAND NEW STILL IN PLASTIC bought from UAS for $550 (thats the price they are everywhere and then realised my cooler piping was in the way. The image isn't my bar BUT its exactly what mine looks like.
PRICE DROPPED TO $350!!!!! what a discount for something that is BRAND NEW!
PARTS FROM AN ECCS SILVER TOP RB20
Intake Manifold lower half:
Complete, comes with 6 injectors, fuel rail, little JECS controller and stock fuel pressure reg and all other electric gizmos Its in good condition, came from an engine i bought to replace my old one. Perfect for using to design a forward facing manifold for your RB20 while keeping your car on the road. (the top half is gone but this is the only pic i have)
Well cheap at $20!!
Stock exhaust manifold and heat sheild $10:
The manifold is in good condition but the heat shield has a little surface rust on it. Good if you're looking to turn your car back to stock for sale.
Cheap as at $10
Stock sump:
Will fit other RB engines, good to turn 4WD blocks into RWD. needs a clean is all
SOLD
Oil Dip Stick:
good condition $5
Water Pump:
Good condition, came off the doner engine which had around 80thou ks has been sitting around for a while though so needs a clean and an oil. (Cam gears have been sold!)
$10
Air-con condensor pump thing:
Calsonic type with the pully and clutch and little pipes coming out of it (been told these are worth about 100 from wreckers etc)
$20!!
ALSO
Machined Rb26 & Internals
All this stuff was completely machined for a rebuild with forged pistons so its all in very good condition but has been in storage for a while, hence the covering of oil to prevent surface rust, so it needs a clean. The low prices reflect the fact that now without a project to put it all in i want this stuff gone! open to reasonable offers
R32 Block, crank and cradle:
lined bored for this crank and cradle and honed to 87mm, crank machined for rebuild, reground contact surfaces, perfectly straight, all parts crack tested and came up 100% ok, all parts pressure washed - $1500 neg
Rods:
machined for rebuild, all contact surfaces reground, crack tested - 100% good - and pressure washed - $150 neg
for more info & pics pm me or see my other post for 'Machined RB26 block and internals'. selling at a massive loss
Edited by Black Betty
https://www.sau.com.au/forums/topic/195660-delete-me/
  • 4 weeks later...
Has the bar been trial fitted to a GTSt? I need an assurance that it does not require modification to fit a GTSt, otherwise the panel beater is going to charge me uber dollars to cut and modify to suit my car :(
absolutely sure it is made to fit an R32 GTS-t
Bought it from UAS as 'GTR style bar to fit GTS-t'.
https://www.sau.com.au/forums/topic/195660-delete-me/#findComment-3671225
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
