bbenny,
Sounds like the AAC valve needs a clean as this basically controls the idle, although in the workshop manual it states that the idle speed, ignition timing,CO and HC density (airflow-meter) are inter-related. Any adjustment to one effects the others and requires an additional inspection.
To clean the AAC valve:
For RB20-25 motor
The AAC valve (Auxilliary Air Control Valve) is located at the back of the plenum chamber (inlet manifold) there is a maroon electrical plug (brittle) and a hose which need to be removed first then there is four ten millimeter bolts that also need to be removed before the whole assembly can be (careful if you want to use the orignal gasket again) removed from the car.
then there is two screws that hold the solenoid on, once this is removed the remaining assembly can be cleaned by useing carby cleaner (compressor to dry and clear any blockages) also make sure that the spring moves(smooth) and the valve works.
Reassemble in reverse order with a bit of sensor safe silicon with the original gasket(or you could make another one it depends on weather the gasket comes off in one piece)
To adjust idle speed From a workshop manual:
The screw that is located on the AAC valve is to control idle speed, But first you need to remove the ECCS control unit(computer) from the passenger side kick panel and there is a screw there that controls idle aswell, now if you can read japanese the writing near the screw says "CAUTION Adjust within indicated range. Do not turn with excessive force" Low idle is at the bottom with high idle at the top and just a little bit past the high idle mark there is self diagnosis. This screw needs to be turned to the low idle mark and the engine warmed then remove the electrical plug from the AAC valve and start engine, Idle should be at 900 rpm, if not turn screw on AAC valve assembly to adjust engine speed to 900 rpm.
Turn screw to the left (counter clock wise) to increase engine idle.
Turn screw to the right (clock wise) to decrease engine idle.
Once the target 900 rpm is achieved plug AAC electrical plug back in and observe if there is any change in Rpm if there is this needs to be adjusted at the ECCS control unit with a maximum of 250 rpm adjustment, another Caution if you turn the screw on the ECCS control unit near the self diagnosis spot it sets the engine speed at the lowest setting Rpm minus 50 rpm.
Sorry for the long and boring post!
MEGA
P.s the AAC valve is located under the plenum on the RB26 and the procedure is the same!
https://www.sau.com.au/forums/topic/19569-bump-in-idle/#findComment-411194
Can also be an airflow problem or your AFM is dirty.
I know after replacing my pod for the stock airbox (with cheap filter), it has less air going in and idles very "lumpy" at the lights. Idle revs jump a bit all over the place as it tries to compensate for the lack of air volume being sucked in.
https://www.sau.com.au/forums/topic/19569-bump-in-idle/#findComment-411427
  • 1 year later...
My slight bump/miss on idle is a dirty injector.
Origionally that is all it was. Now when idling at say 650rpm then stabbing the throttle that car hessitates/slight bump or slight miss then rev's.
Its not really a miss its a half arsed miss. :D
https://www.sau.com.au/forums/topic/19569-bump-in-idle/#findComment-1218686
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
