i agree keep the badge on, its not bad, and cept for the occasional f00 askin u why u have a renalut badge on the car it should b ok.
Unless you completely debadge the entire car for that "wtf is that?" look
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-411875
Originally posted by funkymonkey
nismoR34... luv ya work! i've been looking all over for pics of the R34 badge so I could vectorise it for the SAU cap... hallelujah...
expect a badge on the cap fellas.
:mad: happy to help out ;)
but I dont know if the top one is a 34 badge or not ?
it looks similar to mine ~ i guess
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-411882
yeah same on mine, no stickers nuffin on the back, jus the S on the front. looks sweet coz no one can tell its a GTS, cept for the blue GT badges. (the wheels are covered so no one can tell how many nuts its got.)
https://www.sau.com.au/forums/topic/19570-s-badge/#findComment-412268
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
