Hey guys.
I've decided to sell my pride and joy and end my import ownership for now. I hardly drive the car anymore and it's a waste just leaving it in the garage. it's been my daily for the last year and has never been taken to the TRACK. Surprisingly it's great on petrol and i'd say its around 10-11L per 100km (assumption only).
It's a 1990 R32 which was imported under the 15 year old scheme by Imports101. It was a grade 3.5 car and the car was pretty much stock. It came over with 107xxxkm and I then did a 100,000km service not too long ago, changing the timing belt but the mechanic told me the idler and tensioner have been repalced before and working in perfect condition. it's regularly serviced at 5000km intervals with Castrol Synthetic oil.
MODS:
KM: 120xxx
Separated Dump pipe
3" Front pipe, R33 GTR cat converter and cat-back HKS hipower silent (passed regency with this when it was defected)
Just Jap FMIC kit
Apexi Pod filter
Oil Catch can
Turbotech Boost controller set at 12Psi
ExedyHD Clutch (came with the car) But not yet installed. mechanic reckons approx 70% meat left
Buzz Spec (purple) jap suspension with damper adjust. Firm ride but not too stiff
replaced castor bushers and upper control arm bushes
17" Momo wheels
GTR style front bar, Type M side skirts and rear addons
GTR rear wing
Interior:
TV/DVD (plays MP4, USB, SD card, MP3)
pioneer rear 4" 2 way speakers
Nismo gear knob
Nardi Steering wheel (no boss)
Apexi Boost guage (controller as 1st listed)
Alarm and immobiliser
Clean and all vents intact
Problems:
Its hard to select reverse, pretty much you have to push it in hard after a short drive
touch up on the rear of the car
Aircon doesn't work, have had 3 compressors repalced (got 2nd hand @ wreckers) and none of them have worked. So I've spent approx $500 without no avail wacko.gif. However I can get replacement but CBF getting them to work cos I've just had enough
Price: $9,500 ono or $8,500 stock
Contact: Andy on 0434345424 or pm
MORE PICS:
http://www.nissansilvia.com/forums/index.php?showforum=9
Edited by thanglongz
https://www.sau.com.au/forums/topic/195765-r32-skyline-gtst-manual/
    • Jap premium will be 100 RON. You should use 98.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
