Hey Guys,
When i take the Key out of the Ignition and the Turbo timer is running there is a clicking noise in the Engine bay somewhere. It only clicks when the key is out and turbo timer is running. the HICAS lights flashes continuouslly on the dash and it ticks away like something is trying to Click into place or something..
Any Help????
Doesn't click when key is in and driving so no problems there!!!
https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/
Could well be a relay as they will click. If it is a relay there is a reason for it to be operating. Best to do a diagnostic on the HICAS system. If you dont know how to download the workshop manual.
Deren
Deren
cheers for that mate!!! The Abs Light is on in the dash and apparently the relays are the problem on the ABS unit! could this be the clicking noice even when the hicas light flashes on the dash when the turbo timer is running???
When the engine Is ticking and clicking when turbo timer is running the powersteering pipe seem to rattle near the Battery! like the pipes are not getting fluid in them but it seem to be steering fine!! I think there the steering fluid pipes that run beside the battery and between the radiator!
nope.. because it would be clicking when on idle too.. not jsut when key is out
could it be possible that when u wired it to the ecu that u have a few wires in contact with each other. this may be causing the problem?
Umm i havent touched the Turbo Timer since buying the Car over 5 years ago! Its been going for a few months like this now and it kind of annoying!!! Anyone else out there have this problem??? Where is the HICAS Solenoid anyway???
  • 3 weeks later...
