Styline GTR Posted November 30, 2007 Share Posted November 30, 2007 Hey Guys, When i take the Key out of the Ignition and the Turbo timer is running there is a clicking noise in the Engine bay somewhere. It only clicks when the key is out and turbo timer is running. the HICAS lights flashes continuouslly on the dash and it ticks away like something is trying to Click into place or something.. Any Help???? Doesn't click when key is in and driving so no problems there!!! Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/ Share on other sites More sharing options...
Styline GTR Posted November 30, 2007 Author Share Posted November 30, 2007 Any Help Guys??? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3507163 Share on other sites More sharing options...
Godzilla32 Posted November 30, 2007 Share Posted November 30, 2007 Could well be a relay as they will click. If it is a relay there is a reason for it to be operating. Best to do a diagnostic on the HICAS system. If you dont know how to download the workshop manual. Deren Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3507166 Share on other sites More sharing options...
Styline GTR Posted November 30, 2007 Author Share Posted November 30, 2007 Could well be a relay as they will click. If it is a relay there is a reason for it to be operating. Best to do a diagnostic on the HICAS system. If you dont know how to download the workshop manual.Deren cheers for that mate!!! The Abs Light is on in the dash and apparently the relays are the problem on the ABS unit! could this be the clicking noice even when the hicas light flashes on the dash when the turbo timer is running??? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3507173 Share on other sites More sharing options...
Styline GTR Posted November 30, 2007 Author Share Posted November 30, 2007 And im finding it hard to find replacement Relays for the ABS Unit as well!!! Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3507175 Share on other sites More sharing options...
R32Abuser Posted December 2, 2007 Share Posted December 2, 2007 i doubt it will be the ABS as it happens exactly the same on my car, and mine is a 32 Gts-T (non abs). Someone briefly mentioned the Hicas Solenoid in the engine bay, but im really not quite sure. Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3508775 Share on other sites More sharing options...
Styline GTR Posted December 3, 2007 Author Share Posted December 3, 2007 When the engine Is ticking and clicking when turbo timer is running the powersteering pipe seem to rattle near the Battery! like the pipes are not getting fluid in them but it seem to be steering fine!! I think there the steering fluid pipes that run beside the battery and between the radiator! Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3510060 Share on other sites More sharing options...
GTS4WD Posted December 3, 2007 Share Posted December 3, 2007 When the engine Is ticking and clicking when turbo timer is running the powersteering pipe seem to rattle near the Battery! like the pipes are not getting fluid in them but it seem to be steering fine!! I think there the steering fluid pipes that run beside the battery and between the radiator! nope.. because it would be clicking when on idle too.. not jsut when key is out Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3510234 Share on other sites More sharing options...
Styline GTR Posted December 9, 2007 Author Share Posted December 9, 2007 Any HelP???? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3522704 Share on other sites More sharing options...
lighty01 Posted December 10, 2007 Share Posted December 10, 2007 could it be electrical? something shorting... maybe check in the engine bay at night.. could be shorting making ur hicas light flash? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3523929 Share on other sites More sharing options...
Styline GTR Posted December 14, 2007 Author Share Posted December 14, 2007 Still having Problem! Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3532429 Share on other sites More sharing options...
r33cruiser Posted December 14, 2007 Share Posted December 14, 2007 could it be possible that when u wired it to the ecu that u have a few wires in contact with each other. this may be causing the problem? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3532468 Share on other sites More sharing options...
Styline GTR Posted December 15, 2007 Author Share Posted December 15, 2007 could it be possible that when u wired it to the ecu that u have a few wires in contact with each other. this may be causing the problem? Umm i havent touched the Turbo Timer since buying the Car over 5 years ago! Its been going for a few months like this now and it kind of annoying!!! Anyone else out there have this problem??? Where is the HICAS Solenoid anyway??? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3534321 Share on other sites More sharing options...
Styline GTR Posted January 3, 2008 Author Share Posted January 3, 2008 ????? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3562056 Share on other sites More sharing options...
trism Posted January 3, 2008 Share Posted January 3, 2008 rather than asking for help over the internet, and a month later not being any closer, can i suggest taking it to a mechanic/workshop? Link to comment https://www.sau.com.au/forums/topic/195789-ticking-noice-in-engine-bay/#findComment-3562064 Share on other sites More sharing options...
