hello just wanted to know what needs to be done to fit a r34 neo turbo engine in a r33 s1 turbo skyline...keeping the standed box?? Does anyone know? Ive been told that it bolts straight in.....
Can anyone help and let me know if it does and if not what needs to be done to make it
https://www.sau.com.au/forums/topic/195807-will-a-r34-neo-fit-in-a-r33/
thats good to know..
cause i just brought a r34 neo turbo engine to put in my r33 and wasnt sure! can u still use the r33 wiring loom ....
Is there anythings i need to watch out for??? what about the coil packs what happens there with the r33 coil plugs in to the r34 coils??? thats the only thing missing of the new motor...
Ive got a microtech Lt12s in any way so the ecu is not a problem for me..
mate ill pm u some pictures tonight, and yeh i used my r33 wiring loom, just a bit of customising mainly where the ignitor pack was supposed to be, nothing to hektik though. the motors are pretty much d same power. however with the neo, they got solid lifters, slightly better turbo, and different cam set up. and the r33 gearbox should sit right up. however, i used a 34 gearbox when i did my conversion. not too much work involved so u should be right :)
  • 4 years later...
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
