I'm looking at replacing my front rotors and calipers with those off a R33 GTS25T.
Has anyone done this before?
I have heard they bolt straight on, and apart from a brake bleed/fluid, all should work just fine?
Cheers, Chris
https://www.sau.com.au/forums/topic/19587-r32-gtst-brake-upgrade/
I think the only differance is that 32 GTR rotors are a 2mm thicker than 33 GTS25T, and the same diameter (296mm compared to 280mm on ours)
A set of R33 GTR Brembos would be nice - but they'd cost a fair bit
Do you reckon that the master cylinder will still be OK? I can't see any dramas with swapping calipers, so it should be OK. I'm hoping to swap mine over and pay the differance for the calipers and get some DBA slotted rotors with decent pads, probably from Race Brakes or somewhere similar
Master cyliner will be fine, the brakes have just got bigger pistons giving more force but they are not large enough to cause a problem. I saw some 33 Brembro on performance forums for 1600 which is a good price. But i want the option of being able to use 16'' wheels so the 32 gtr brakes are the go and with decent pads and braided lines will give good performance for the lighter gtsts like ours.
Guest Boxhead
im with slip here, eheck your pads, if low, replace with some decent pads, then get some good fluid in there, i used the motul race stuff, its apparently better then dot5.1....
and it made a hell of a difference, you will be surprised the crap that will come out when you flush your system.
For WW2 you will need things for GO mate, non of this slowing down bisso. Look at grepin, he's now got 60% more power than stock and his brakes and fluid are the same from when the car left the factory in Japan!
Im with Slip,
I've got an R33 gtst
bought a set of DBA slotted rotors, only to put them on and find
that both the width and ofset were wrong..
actually damaging the rotors
with that DBA refused to take the rotors back even after they assured me they would ... so if you go this way..check them first
Didn't end up going with the R33 GTS25T brakes, I got some slotted rotors and Race Brakes pads (of Clint32's car which is getting GTR brakes
Didn't think they would make much a differance, but I was wrong!!
Stops heaps better than before, I can now get that good g-force feeling under acceleration and braking now
Will need a track day to give them a good test, but so far so good
Also, big thanks to Clint for helping me out with them - cheers mate
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
