Where Do I Get Cheap Exchange Order Forms For Jr Pass?
Yes, just throw some gaskets at it and put it back in. As long as everything is actually designed to bolt up together it will all go back together. My CA compliant exhaust for example can only fit with the specific catback I gave them. -
By aligatorcat · Posted
Sorry I missed this. I ended up getting one locally. Appreciate your time to help. -
By thomasLait · Posted
Yes it is, the nm35 stagea has OBDII idk if the WC34 has it tho -
Talk to Avondale Body Works, had a repair done there long ago and was a good experience.
So that will really depend on what else was changed when it came out. If it is the same front pipe and the same cat back, then yes. Plus you might have to work out what they did with the themperature sensor.
